Problems with defining the area for velocity inlet |
August 16, 2017, 06:58 |
Hello everyone,
I'm trying to create a velocity profile for a cylinder's wall that is treated as velocity inlet. What I'd like to do is to restrict the area (by height) in order to make a profile that is better suited for my case. (3D simulation) For instance this is the part that is used for axial velocity at the moment, but it doesn't differ from the normal velocity profile without the UDF: DEFINE_PROFILE(vA_liq,thread,i) { face_t f; float x[ND_ND]; float zpos; begin_f_loop(f,thread) { F_CENTROID(x,f,thread); zpos=x[2]; if (zpos<=-0.66316 && zpos>=-1.65) // GIVE THE EXACT Z-AXIAL IN m F_PROFILE(f,thread,i)=-1.15; else F_PROFILE(f,thread,i) = 0; } end_f_loop(f,thread) How can I get it to restrict the area used for velocity inlet by setting the restraint on z-axis values? Thank you in advance. Last edited by Eunikki; August 17, 2017 at 03:08. |
problems when using sonicFoam with subsonic inlet BC | JasonWang3 | OpenFOAM Pre-Processing | 2 | June 22, 2015 04:55 |
[swak4Foam] GroovyBC problem in the defining inlet velocity | iampolaris | OpenFOAM Community Contributions | 7 | October 18, 2014 09:25 |
Inlet and outlet definition problems | ethanmcmillan | FLUENT | 0 | April 9, 2012 19:32 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
