Access to temperature gradient C_T_G
I wanted to define a shear boundary condition as a function of temperature gradient. Following is the UDF I wrote for this purpose. The UDF only returns the the constant value of 0.0 since the temperature gradient is not accessible. However, from the contour plots, I can see that temperature gradients are available after the first iteration. If I remove the "if" statement, I receive this error: Error: received a fatal signal (Segmentation fault). Error Object: #f I should mention that I keep temporary solver memory from being freed. Any help to solve this problem is highly appreciated. #include "udf.h" #include "mem.h" DEFINE_PROFILE(WSS, t, i) { face_t f; cell_t c; real TG; begin_c_loop(c,t) { if (NNULLP(THREAD_STORAGE(t, SV_T_G))) { printf("Gradient of Temperature is available \n "); TG = NV_MAG(C_T_G(c,t)); C_PROFILE(c,t,i)=-0.0001*TG; } else { C_PROFILE(c,t,i)=0.; } } end_c_loop(c,t) } |
Alloc_Storage_Vars(domain, SV_T_RG, SV_T_G, SV_NULL); T_derivatives(domain); ......... your code.... ......... Free_Storage_Vars(domain, SV_T_RG, SV_NULL); Free_Storage_Vars(domain, SV_T_G, SV_NULL); |
what are the arguments for this macros for accessing species mass fraction? |
from manual
now I have used C_UDSI_G to calculate current density successfully in a cas, it can be seen in post-processing, then I write cas and dat. Now I read cas, and when I read dat it shows: https://cmct.xyz/images/2020/10/06/S...6_10-17-16.png the process of fluent has already down. I've know the reason for it:when I read dat, it can't access the value of C_UDSI_G immediately because I used define_profile macros and it would first be called: https://cmct.xyz/images/2020/10/06/1.png now if I change the value to constant like this: https://cmct.xyz/images/2020/10/06/2.png and also need to calcalate for one iteration,until then it won't get wrong when I read dat.:(:(:( so I wonder if there's a way to read dat normally without these procedure... |
unfortunately, no idea, how to deal with it.
try to remove reading from .dat step. simulate everything without exit from fluent |
use SV_UDS_I, SV_UDSI_G; SV_T_G, SV_H_G
DEFINE_ADJUST(adjust_sources,d) Best |
Hi, Yes, I have checked its effectiveness and in fact I am working on a problem where 3 UDSIs are present and I am using gradients of 2 UDSIs. Without that "if(NULL!=....)" statement my UDF was not working because no memory was allocated to them and when I call them in UDF (i.e., for example C_UDSI_G(c,t,0)[0]), it threw the segmentation fault. When I used that statement my UDF worked fine. Also I checked those gradients by storing them in UDMI's, I and found reasonable results. Quote:
Ok, what I meant was to use the following (I am directly copying from the code I am using): Code:
if (NULL != THREAD_STORAGE(t, SV_UDS_I(0)) && rest your wish, I just thought to respond to this thread, although I was not linked to this thread. And I only write on those problems in cfdonline forums in which I too have faced problem at certain stage. |
begin_f_loop(f,f_thread) |
You forgot to put brackets after your if statement. Indentation is only for the programmer, not relevant for the compiler.
you can prevent the solver from freeing up memory by issuing the text command solve/set/expert yes
you will find the result after computation |
