UDF for finding a flow time where a condition is met
Hello All,
I am trying to write UDF for post-processing and DOE. However, I don't write them too often and newer from the scratch so that's why I post this question. I am somehow familiar with C abut I work mostly with Python. Below the problem description. I run transient state heat-transfer analysis. What I am interested in is a time point (flow time) at which a maximum temperature at a given (named) face is reached for the first time. The logic of the function should be something like this: time_point = -1Do you have any ideas what would be the best approach to this UDF? Or maybe there is another way to do this? So far I am able to do it manually by exporting the face monitor data and post-process them outside FLUENT but i would like to have it as a results parameter. Thank you in advance! |
