cell field variable for electric current density
I need to write a UDF for a heat source which is a function of electric current.
What is the cell field variable for electric current density? I did not find anything in UDF manual. Thanks in advance. |
I have activated the electric potential model in fluent which allows me add joule heating and electric potential in the model. However, I need to add additional heat source which is a function of electric current. What I understand from fluent manual is that I need to write a UDF using the define_source macro. but to write my equation in that UDF, I need to know the cell field variable for current density which I did not find in the manual.:confused::confused::confused:
If your are talking about Single-Potential Battery Model, you may find source for that model in fluent files, by default the path is:
C:\Program Files\ANSYS Inc\v182\fluent\fluent18.2.0\addons\battery\src in file battery.h you may find information about UDF variables: Code:
enum { Best regards |
Thanks a lot for your reply.
I assume the UDM index of Battery module would be different from other modules. For my model, I either have to use the MHD module or the electric potential model available in fluent 17.2. Unfortunately, I could not find a similar .c or .h source file for MHD module in MHD module directory. |
Did you find the cell variable for electric current density?
i'm writing a UDF for galvanic corrosion rate and would like to call the electric current for each cell to calculate the corrosion rate. and as a general question, is there a list somewhere the available cell variable one can retrieve using the "real" command? |
