Access inlet mass flow value (target mass flow rate)
Hello everyone,
I need to specify the mass flow rate percentage through multiple outlets, just as in outflow boundary condition, but using pressure-outlet boundary condition instead, and target mass flow rate option. The inlet mass flow varies with time. How can I retrieve this value ? I've created the UDFs, but the results are weird. I think I am not retrieving the correct inlet mass flow. --------------------------------------------------------------------------- Here is the code I've created: DEFINE_PROFILE(target_massflow_left1,outlet_thread ,massflow) { face_t f; face_t inlet; Domain *domain; real percentage = 0.24; int inlet_zone_id = 61; real inlet_massflow; domain = Get_Domain(1); //fluid domain Thread *inlet_thread = Lookup_Thread(domain,inlet_zone_id); //thread containing inlet begin_f_loop(inlet,inlet_thread) { if(BOUNDARY_FACE_THREAD_P(inlet_thread)) //found inlet { inlet_massflow = -F_FLUX(inlet,inlet_thread); } } end_f_loop(inlet, inlet_thread); //loop over every face on the thread begin_f_loop(f,outlet_thread) { F_PROFILE(f,outlet_thread,massflow) = percentage * inlet_massflow ; } end_f_loop(f, outlet_thread); } ---------------------------------------------------------------------------------- Thanks in advance, YCarv |
To get the total inflow, you need to sum the inflow overall faces in the inlet.
real inlet_massflow=0; |
oh, of course !
Thank you very much pakk, I will try this now ! |
