DPM Switching doesn't switch law when I have specified |
April 11, 2018, 15:39 |
sunil kumar
Rep Power: 9 |
I have set a DPM switch so that the laws change with a user defined scalar but the laws are not switching when I have specified. Does anyone know why this is
Material *m = TP_MATERIAL(tp); if (TP_USER_REAL(tp,0) > 0.5) { TP_CURRENT_LAW(tp) = DPM_LAW_USER_1; } if (TP_USER_REAL(tp,0) <= 0.5) { TP_CURRENT_LAW(tp) = DPM_LAW_INITIAL_INERT_HEATING; } |
April 11, 2018, 22:03 |
Alexander
Rep Power: 34 |
code looks correct (comparing to example from manual)
did you hook your function in fluent GUI? you may try to check your condition (TP_USER_REAL(tp,0) > 0.5) using Message function: Code:
DEFINE_DPM_SWITCH(dpm_switch, tp, coupled) { Material *m = TP_MATERIAL(tp); int i=0,j=0; if (TP_USER_REAL(tp,0) > 0.5) { TP_CURRENT_LAW(tp) = DPM_LAW_USER_1; if i==0 {Message0("in DPM_LAW_USER_1 \n"); i++;} } else { TP_CURRENT_LAW(tp) = DPM_LAW_INITIAL_INERT_HEATING; if j==0 {Message0("DPM_LAW_INITIAL_INERT_HEATING \n "); j++;} } } |
April 12, 2018, 03:49 |
sunil kumar
Rep Power: 9 |
Yes I have hooked the function in the GUI.
It moves into the heating law as it displays the message but the law is not doing what I am expecting it to do. That was very helpful thank you I will have to give it some further investigation. |
April 13, 2018, 03:39 |
Rep Power: 11 |
Hi AlexanderZ,
Is the intention of i and j to get the information messages only once? With your code as suggested, this will not happen, because i and j are initialised to 0 on every visit. To get only one message, you would need to define i and j as static variables outside the UDF: Code:
static int i=0,j=0; DEFINE_DPM_SWITCH(dpm_switch, tp, coupled) { Material *m = TP_MATERIAL(tp); if (TP_USER_REAL(tp,0) > 0.5) { TP_CURRENT_LAW(tp) = DPM_LAW_USER_1; if (i==0) {Message0("in DPM_LAW_USER_1 \n"); i++;} }else { TP_CURRENT_LAW(tp) = DPM_LAW_INITIAL_INERT_HEATING; if (j==0) {Message0("DPM_LAW_INITIAL_INERT_HEATING \n "); j++;} } } Ed |
April 14, 2018, 03:44 |
Alexander
Rep Power: 34 |
thank you for comment.
with i and j i wanted to run message function only once. we may put i and j in DEFINE_EXECUTE_AT_END macros to set i and j = 0 after each time step. For that case we should define i and j as global variables. best regards |
Display Modes | |
DPM Switching | skumar112 | Fluent UDF and Scheme Programming | 0 | April 4, 2018 12:10 |
DPM UDF for switching law | amilachandra | Fluent UDF and Scheme Programming | 1 | September 15, 2016 03:43 |
UDF for Drag law in DPM | mail.leonardo | Fluent Multiphase | 1 | July 18, 2016 03:41 |
UDF for DPM Law Switch | Leepox | Fluent UDF and Scheme Programming | 0 | August 26, 2013 05:36 |
questions about the DPM law | rookie | FLUENT | 0 | June 16, 2003 11:41 |
