April 25, 2018, 01:47 |
Profiles(Text file) into UDF_DEFINE SOURCE
Rep Power: 13 |
Hello, i am panic in applying the profiles in to UDF_DEFINE SOURCE
I want to define source with "eg" depending on location x, y. I have a text file with the information of "eg" as a series of data with x,y coordinates. I failed to make a function like eg= f(x,y). So I want to read directly the profile on the fluent. (profiles -> fluent) Reading the profiles from the fluent was successful But, desparately, i can not get any sense applying "eg" profiles (uploaded in fluent) to UDF code If you know some hint, please help me TT "eg" profiles example ((eg 5 point) (x 0.2 0.35 0.7 0.9 0.91) (y 0.00147406 0.00147546 0.0014834 0.00148353 0.00139519) (eg 0.8269 0.81492 0.88675 0.75573 0.83069) UDF code shown below ===================================== DEFINE_SOURCE(xmom_src,c,t,dS,eqn) { double src,x[ND_ND],source,base1,base2; C_CENTROID(x,c,t); { src = C_MU_L(c,t)*eg/pk; source = -src*C_U(c,t); dS[eqn] = -src; break; } return source; } |
April 25, 2018, 02:35 |
Rep Power: 26 |
If your scheme variable is just one number, you can read it in a UDF as:
RP_Get_Real("variable-name") |
April 25, 2018, 03:04 |
Rep Power: 13 |
Thank you for your kind reply!!!
I am searching with your hint. If you have any more information, please reply me for help. Thank you!! |
April 25, 2018, 05:16 |
Alexander
Rep Power: 34 |
you may define your table in udf and use interpolation to get heat source according to coordinate
this code may help you Code:
#include "udf.h" #include <stdlib.h> #include <stdio.h> #define N 10 float Temp[N] = { 300 301 302 303 304 305 306 307 308 309 } float Heat[N] = { 100 201 302 403 504 605 706 807 908 1009 } DEFINE_EXECUTE_ON_LOADING(report_version, libname) { Set_User_Memory_Name(0,"My heatsource [W/m3]"); } DEFINE_SOURCE(UDF_heat_source, c, t, dS, eqn) { return C_UDMI(c,t,0); } DEFINE_ADJUST(adjust_heat_source, d) { Thread *t; cell_t c; real source,T; real j, Tpre, Tcur, Hpre, Hcur, A, B, M; thread_loop_c(t,d) // loop over all cells in model { begin_c_loop(c,t) { M=N-1; T = C_T(c,t); if(T<Temp[0]) { source = 0; } for(j=1;j<=M;j++) { if(T>=Temp[j-1] && T<Temp[j]) { Tpre = Temp[j-1]; Tcur = Temp[j]; Hpre = Heat[j-1]; Hcur = Heat[j]; A = (Hcur - Hpre)/(Tcur - Tpre); B = Hcur - (Tcur * A); source = (A*T)+B; C_UDMI(c,t,0) = source; } } } end_c_loop (c,t) } |
April 25, 2018, 05:39 |
Rep Power: 13 |
Dear AlexanderZ
Thank you very much i got the key information about interpolation from your reply However, my data are actually about 120 data and each "eg" depends on both x and y coordinates. Even if i tried to get some fitting function with MATLAB, i failed. So i want to apply whole 120 data points with profiles to fluent directly. Is there any method connecting the profiles in UDF?? Thank you TTTT |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
