the difference of pressure calculated by fluent and udf
Like Tree1Likes
  • 1 Post By pakk
Old   October 11, 2020, 07:42
Default the difference of pressure calculated by fluent and udf
lbj007 is on a distinguished road
I'm using incompressible ideal gas model,and when I use UDM to monitor the pressure,I find it is different from the value calculated by fluent's counter.I don't understand
#include"udf.h"
#define H2 0
#define H2O 1
#define N2 2
#define O2 3
#define SO2 4
#define NUM_SPECS 5
#define R 8.31447
#define pi 3.14159
#define F 96485
DEFINE_DIFFUSIVITY(gas_diff,c,t,i)
	real v[4],y[4],Dkn[4],D[4][4];
	real M[4]={2e-3,18e-3,28e-3,32e-3};
	real tem=C_T(c,t);
    concen0=C_R(c,t)*C_YI(c,t,0)/M[0];     /*H2*/
    concen1=C_R(c,t)*C_YI(c,t,1)/M[1];     /*H2O*/
    concen2=C_R(c,t)*C_YI(c,t,2)/M[2];     /*N2*/
    concen3=C_R(c,t)*C_YI(c,t,3)/M[3];     /*O2*/
    concent1=concen0+concen1;               /*Anode*/
    concent2=concen2+concen3;               /*cathode*/
    p1=concent1*R*tem;
    p2=concent2*R*tem;
	C_UDMI(c,t,14)=p1;
	C_UDMI(c,t,15)=p2;
Here the mole fraction of SO2 is always zero,and there are H2 and H20(g)in the anode,N2 and O2 in the cathode, for additional explanation.
lbj007 is offline   Reply With Quote
Old   October 11, 2020, 08:04
does it due to that fluent uses Density = P_operate/(R*T),it is a constant,and in udf the density is not a constant?
Old   October 12, 2020, 06:44
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
not sure, but you may check it
macro to get operating pressure is
p_op = RP_Get_Real("operating-pressure");
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 12, 2020, 07:20
but operating-pressure is the value you set in fluent,it is of course a constant..
Old   October 20, 2020, 09:47
pakk will become famous soon enough
It might help if you share the value that fluent shows, and the value that your UDF shows.
pakk is offline   Reply With Quote
Old   October 21, 2020, 05:48
I've already showed the picture.
Old   October 22, 2020, 22:32
I don't see any picture.
Old   October 23, 2020, 08:40
can you open: http://cdn.img.headns.com/2010/3934b2dcef76f.png
Old   October 23, 2020, 12:26
Very nice picture.
Now back to the topic: which value does fluent give, and which bakkie does your UDF give? You say they are different, shoe me the difference!
Old   October 23, 2020, 22:55
Very nice picture.
what I've given you is fluent's value,and here is the udf's value:http://cdn.img.headns.com/2010/395056fbb492a.png
Old   October 23, 2020, 23:12
Looking at the minima: one says 101083 Pa, the other 101325 Pa. That is a difference of only 0.2%, very small.
So, what small inaccuracy do you have in your code? I think the values of the molecular weights.
lbj007 likes this.
Old   October 24, 2020, 07:32
ok,I got it.Thanks
post-processing, pressure, udf
how to put udf inlet velocity and udf outlet pressure in fluent raminostadi Fluent UDF and Scheme Programming 4 July 3, 2017 06:43
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
Calling zone name, zone id and total pressure from Fluent scheme to UDF kuldip Fluent UDF and Scheme Programming 2 October 6, 2014 00:23
Fluent 5.2, UDF and Pressure BC's Alfonso Ferrandez FLUENT 0 May 4, 2000 07:02
