How to use a UDF to assign a temperature to cells that is within a range of z coord |
January 23, 2023, 09:38 |
Khanh Dang
Rep Power: 3 |
Could I get help with writing my first UDF in Fluent? I have written a UDF to assign a temperature to the cells whose z-coordinates are within a specified range. But it doesn't seem to work. Could everyone take a look at my code and point what I have done wrong? I'm doing a series of transient simulations of the heat transfer between food cans and hot gas in a convection oven. I have a 228-in length filled with cans, and the can locations are periodic such that there are 19 units of cans. Each unit is 12 in long. I want to use the UDF to set an initial temperature for the first unit of cans (Unit 1) and then solve for 16 s. Then, the current temperature of the Unit 1 will be the initial temperature of Unit 2. I will repeat this procedure until Unit 19. I used DEFINE_ON_DEMAND instead of DEFINE_INIT because I'm using a steady-state solution as the initial solution for the hot gas. Thank you so much in advance for your time and help! Code:
#include "udf.h" DEFINE_ON_DEMAND(can_unit_1_temp) { /* declare domain pointer since it is not passed as an argument to the DEFINE macro */ Domain *domain; domain = Get_Domain(1); /* get the cell thread pointer by using the macro Lookup_Thread(domain, zone_id) instead of thread *ct */ int id = 55; /* ID of can solid cell zone */ Thread *ct = Lookup_Thread(domain, id); cell_t c; /* cell index - an special Ansys Fluent data type */ real pos[ND_ND]; /* loop through all the cells in the cell thread of the can solid */ begin_c_loop(c,ct) { C_CENTROID(pos,c,ct); if (0.1524 < pos[2] && pos[2] < 0.4572) /* the first 12 inch of cans (unit 1) is between 0.1524 and 0.4572 m */ C_T(c,ct) = 600.0; } end_c_loop(c,ct) } |
February 4, 2023, 10:52 |
Alexander
Rep Power: 34 |
code seems to be ok
by default fluent uses SI for all UNITs so check your values, that could be a problem Code:
best regards ****************************** press LIKE if this message was helpful |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 00:11 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
