Modification on Ranz-Marshall Model for granular flow |
August 28, 2018, 08:28 |
Emerson
Rep Power: 7 |
Hello all,
I'm new with Fluent and UDF. I want to make a modification on the Ranz-Marshall Model using a base UDF given in the documentation. This modification is simply to change the constants and add a Gamma expression. The purpose is to test if this function will help me to heat a granular phase with a gas phase entering in a domain at 2373 K (blast furnace tuyere process) My doubt is: this UDF that I wrote is really taking the properties of the granular secondary phase (Eulerian-Eulerian)? I'm already using the UDF and fluent successfully read it. Here are the subroutines: -------------------------- FLUENT DOCUMENTATION Ranz-Marshall Model #include "udf.h" #define PR_NUMBER(cp,mu,k) ((cp)*(mu)/(k)) #define IP_HEAT_COEFF(vof,k,nu,d) ((vof)*6.*(k)*(Nu)/(d)/(d)) static real heat_ranz_marshall(cell_t c, Thread *ti, Thread *tj) { real h; real d = C_PHASE_DIAMETER(c,tj); real k = C_K_L(c,ti); real NV_VEC(v), vel, Re, Pr, Nu; NV_DD(v,=,C_U(c,tj),C_V(c,tj),C_W(c,tj),-,C_U(c,ti),C_V(c,ti),C_W(c,ti)); vel = NV_MAG(v); Re = RE_NUMBER(C_R(c,ti),vel,d,C_MU_L(c,ti)); Pr = PR_NUMBER (C_CP(c,ti),C_MU_L(c,ti),k); Nu = 2. + 0.6*sqrt(Re)*pow(Pr,1./3.); h = IP_HEAT_COEFF(C_VOF(c,tj),k,Nu,d); return h; } DEFINE_EXCHANGE_PROPERTY(heat_udf, c, t, i, j) { Thread *ti = THREAD_SUB_THREAD(t,i); Thread *tj = THREAD_SUB_THREAD(t,j); real val; val = heat_ranz_marshall(c,ti, tj); return val; } ------------------ Ranz-Marshall Model MODIFIED #include "udf.h" #include "math.h" #define PR_NUMBER(cp,mu,k) ((cp)*(mu)/(k)) #define IP_HEAT_COEFF(vof,k,nu,d) ((vof)*6.*(k)*(Nu)/(d)/(d)) static real heat_ranz_marshall(cell_t c, Thread *ti, Thread *tj) /* i -- gas phase; j -- granular-phase */ { real gamma; /*paper shen*/ real t_sec = C_T(c, tj); /*secondary phase (coke) temperature*/ gamma = 0.2 - 0.18*MIN(1.0, MAX(0, (t_sec - 1473.) / 200.)); real h; real d = C_PHASE_DIAMETER(c, tj); /*secondary phase (coke) diameter*/ real k = C_K_L(c, ti); real NV_VEC(v), vel, Re, Pr, Nu; NV_DD(v,=, C_U(c, tj), C_V(c, tj), C_W(c, tj), -, C_U(c, ti), C_V(c, ti), C_W(c, ti)); vel = NV_MAG(v); Re = RE_NUMBER(C_R(c, ti), vel, d, C_MU_L(c, ti)); Pr = PR_NUMBER(C_CP(c, ti), C_MU_L(c, ti), k); Nu = 2. + 0.6*pow(Pr,0.333)*pow(9.*Re,0.5); h = IP_HEAT_COEFF(C_VOF(c, tj), k, Nu, d); h = gamma*h; return h; } DEFINE_EXCHANGE_PROPERTY(heat_udf, c, t, i, j) { Thread *ti = THREAD_SUB_THREAD(t, i); Thread *tj = THREAD_SUB_THREAD(t, j); real val; val = heat_ranz_marshall(c, ti, tj); return val; } --------------------------- Can anyone help with ANY suggestions? If need more details, just ask. Sorry for my bad English. PS: the formulas are attached Paper: Three-Dimensional Modeling of Flow and Thermochemical Behavior in a Blast Furnace (YANSONG Shen, BAOYU GUO, SHENG CHEW, PETER AUSTIN, and AIBING YU) Results so far: I can't heat my granular phase with my gas (Figures attached) Last edited by souza.emer; August 28, 2018 at 08:37. Reason: Forget the results with the previous try |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Coupling Radiation with Flow model | tongx051 | FLUENT | 0 | October 22, 2011 16:03 |
