Variable names for mass flux for a recirculating-outlet boundary condition |
February 3, 2010, 11:25 |
Anonymous
I want to use the recirculating-inlet/recirculating-outlet boundary condition with Fluent 12. It works fine, however, I need to be able to modify the mass flux such that it is a function of the inlet average temperature of the face. In doing so I can use the define_profile function, I just need to know the variable name used in fluent so I can return it. Please help if you can! Thanks. |
July 8, 2010, 17:45 |
Recirculation UDF
Paul
Rep Power: 16 |
Does anyone have a recirculation Fluent UDF written they can share? I know this is openly available in Icepak (just by canceling a solve and checking the two recirculation boundary conditions). Please post in this thread if you have it. Thanks. |
July 12, 2010, 12:33 |
Paul
Rep Power: 16 |
Enter following commands in TUI:
(rpsetvar 'icepak? #t) (models-changed) Two boundary conditions are added: Recirculation-Outlet and Recirculation-Inlet The alternative of writing the UDF uses DEFINE_ADJUST and you can read about this in the Fluent User Manual. |
November 16, 2011, 00:47 |
how to extract the value of last time step?
xiaokang
Rep Power: 14 |
I am try to solve a recirculation prolem, that is like: a domain has a particle inlet. the particle flux is unknown. I want to use the particle flux of outlet at the last timestep. So does anybody know how to extract the certain value of the last time step?
thanks! |
November 13, 2015, 18:03 |
Mahmoud said
Dear Sir
How can you activate the recirculation inlet and outlet in fluent program. I am trying to use this command but it doesn't work, and give me invalid command. Best regards |
November 15, 2015, 09:31 |
#6 | |
Mahmoud said
Dear sir I have read your post (Recirculation Boundary Conditions in ANSYS FLUENT) You said "to turn on the recirculation inlet and outlet boundary conditions in fluent you need to enter this command"(rpsetvar 'icepak? #t) (models-changed) I have entered this command in TUI but give me this massage Invalid command Can you help me to do it in a correct way? |
November 20, 2017, 01:35 |
Can'd do recirculation boundary condition
Ram Prakash
Rep Power: 8 |
I am also looking for the recirculation boundary condition. These commands are (rpsetvar 'icepak? #t)
(models-changed) not working in my fluent in workbench 15.0. Can anybody help me? |
September 4, 2018, 13:49 |
#8 | |
Variable boundary condition | Sae. kil | CFX | 0 | November 19, 2008 11:00 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Outlet boundary condition for pd in InterFoam | gopala | OpenFOAM Running, Solving & CFD | 0 | March 19, 2008 09:26 |
Outlet boundary condition in my pipe ???? | Asghari | FLUENT | 2 | July 14, 2006 01:02 |
Question about the outlet boundary condition. | G.H.Lee | Main CFD Forum | 5 | April 29, 1999 04:50 |
