June 19, 2019, 03:19 |
UDF for VOF Modeling
Yunus Emre
Hey dear guys. I need your help.I am doing inner flow analysis.
Always I do this analysis in CFX . But I want to test FLUENT's power. How different are the solution times ? etc... This component is an injector. I have a lot of expressions when using CFX. There are an example below picture. My purpose is doing same analysis in FLUENT. I need these expressions to control TAU angle ksi angle.. etc.. I should see TAU Angle values end of the analysis on postprocess. I am using VOF model on FLUENT but you know VOF model has some limitations. So I don't acquire velocity components each phase. Such as fuel superficial velocity X Y and Z. I guess I have to write UDF to acquire these components. And then I will use this component for aquiring TAU and ksi angle But I don't know writing UDF codes. this ksi angle is below picture. . My whole purpose is to post process this. Can you help me. Then I will Vof to DPM analysis for spray. My one of purposes is to use VOF to DPM model on FLUENT. for detailed information https://www.ansys.com/blog/fluent-19-speeds-cfd-spray-simulations |
June 20, 2019, 00:43 |
Alexander
Rep Power: 34 |
September 13, 2019, 09:08 |
cheng qiang
Rep Power: 12 |
Hi metafizix,
Do you have the tutorial of the Fluent VOF-to-DPM model. I can not find the tutorial from the Ansys customer portal. Please send it me if you have. My email address is: qiang.cheng@aalto.fi. Thanks in advance. Best Regards, Jonny |
UDF of Modeling Heterogeneous Reaction with Eulerian-Granular flow | Yuting | FLUENT | 11 | September 1, 2022 00:54 |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF for Humidification modeling | Vivek | Main CFD Forum | 0 | June 13, 2006 11:48 |
DEFINE_DPM_OUTPUT macro UDF HELP | Puneet | FLUENT | 3 | November 28, 2003 10:55 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
