UDF coding for dynamic mesh Needle valve lifting |
July 18, 2019, 01:52 |
Jiwon Yoon
Rep Power: 7 |
Hello
I'm having trouble coding a needle valve lift for a fuel injectior. I have set my geometry and mesh but the udf code for dynamic mesh is harsh. Please help me out with coding of UDF or indications would also be very helpful. the maximum lifting length for the needle valve is 0.8(mm) and power stroke time length is 0.000232(sec) |
July 29, 2019, 01:48 |
Svetlana Tkachenko
What should the UDF do?
August 19, 2019, 05:20 |
dear Светлана
Jiwon Yoon
Rep Power: 7 |
Trying to make a up and down movement(Y-axis movement) of 0.8mm with my geometry model.
upward movement should take place with velocity of 0.65m/s during time 0~0.0014 sec. downward movement should take place with velocity of 0.43m/s during 0.0014~0.0033 sec. down below is my UDF but it does not compile properly #include "udf.h" #include "dynamesh_tools.h" DEFINE_CG_MOTION(nozzle, dt, cg_vel, cg_omega, time, dtime) { /* reset velocities */ NV_S (cg_vel, =, 0.0); NV_S (cg_omega, =, 0.0); /* compute velocity formula */ if (time <= 0.0014) { cg_vel[1] = 0.65; } else if (0.0014 < time < 0.0033) { cg_vel[1] = -0.43; } else { NV_S (cg_vel, =, 0.0); NV_S (cg_omega, =, 0.0); } message("\n"); message("\n y_velocity = %g \n",cg_vel[1]); } any corrections to UDF or suggestions would be VERY helpful |
dynamic mesh, udf |
UDF /Dynamic Mesh Query | Subodh21 | Fluent UDF and Scheme Programming | 4 | August 29, 2017 05:06 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
