UDF for specific heat as function of pressure
Like Tree2Likes
Old   February 24, 2014, 13:02
Default UDF for specific heat as function of pressure
Gustavo
ghobold is on a distinguished road
I am trying to make an UDF to obtain specific heat as a function of temperature and other state variable (either pressure or density, hopefully). The problem is that the default macro for specific heat DEFINE_SPECIFIC_HEAT passes only temperature as a state variable and does not inform on the cell or thread. This is what I have tried to do in order to obtain the pressure in the cell:
#include "udf.h"
const char* FLUID = "CarbonDioxide";
const real gauge = 101325; //operating pressure in pascal (as defined in fluent)
double Props (char*, char, double, char, double, char*);
/* other macros here */
DEFINE_SPECIFIC_HEAT(cell_specificHeat, temperature, Tref, enthalpy, yi)
	real pressure;
	 Domain *domain = Get_Domain(1);
	 Thread *t;
	 cell_t c;
	 thread_loop_c(t, domain)
	 	begin_c_loop(c, t)
	 		pressure = C_P(c, t);
	 	}end_c_loop(c, t)
	real specificHeat;
	specificHeat = Props((char*)"C",'T', temperature, 'P', pressure, (char*)FLUID)*1000;
	*enthalpy = specificHeat*(temperature-Tref);
	return specificHeat;
Props(), in this case, is a function from a loaded library Coolprop (Coolprop works fine with Fluent, by the way, I'm using it to obtain other real gas properties and it works just fine). Whenever I initialize a solution using the code above, the following error pops up:
/home/ansys_inc/v145/fluent/fluent14.5.7/lnamd64/2ddp_node/fluent_mpi.14.5.7: symbol lookup error: libudf/lnamd64/2ddp_node/libudf.so: undefined symbol: _Z10Get_Domaini
MPI Application rank 1 exited before MPI_Finalize() with status 127
999999 (../../src/mpsystem.c@1172): mpt_read: failed: errno = 104
999999: mpt_read: error: read failed trying to read 4 bytes: Connection reset by peer
 The fluent process could not be started.
It seems like the UDF does not recognize the function Get_Domain() and is trying to look for it in the compiled Coolprop library instead of the default Fluent library. Am I doing something wrong or is there another (and hopefully faster, computational time wise) way to do this?
I'm running Fluent 14.5.7 on Fedora 19, in case that's relevant.
ghost82 likes this.
ghobold is offline   Reply With Quote
Old   March 2, 2014, 07:14
Gustavo
I'm still very interested in this problem, so if someone has a suggestion, it would be more than welcome.
Old   March 3, 2014, 09:58
Peter Aestas
aestas is on a distinguished road
i never have this problem,but it's clear the loop is wrong:
begin_c_loop(c, t)
}end_c_loop(c, t)
this will only make pressure equal the last cell value it loops.
aestas is offline   Reply With Quote
Old   March 5, 2014, 11:36
Gustavo
begin_c_loop(c, t)
}end_c_loop(c, t)
Thanks for your reply. How should I structure the loop in a way I can grab the cell's pressure value? I still have no idea on how to deal with those loops, so if you have any source it would be welcome. The manual doesn't seem to provide a clear explanation.
Old   March 5, 2014, 12:35
ghost82's Avatar
Rick
ghost82 will become famous soon enough
It's not possible with macro DEFINE_SPECIFIC_HEAT.
Maybe your idea is good to load external library.
ghost82 is offline   Reply With Quote
Old   March 5, 2014, 12:56
Gustavo
My plan is to load an external library. A Fluent wrapper for the open-source thermodynamic library Coolprop is under development and I am using it in my implementation.
As mentioned in the UDF I posted, Props() is a C function that will get the value of specific heat as a function of two state properties (such as temperature and pressure, or temperature and density). The problem is that the DEFINE_SPECIFIC_HEAT does not pass the cell value of pressure or density, so I am not able to consult the external library. So that's why I am trying to find a way to get the value of pressure in the cell. Is there any other macro that would help me in defining specific heat as a function of temperature and other thermodynamic property?
I have also noticed that the bult-in NIST REFPROP library in Fluent does not compute specific heat as a function of pressure, only temperature.
Old   March 6, 2014, 07:24
pakk will become famous soon enough
When the udf DEFINE_SPECIFIC_HEAT is called by Fluent, Fluent does not give information about density or pressure. You already saw that.
However, Fluent also does not give information about which cell it currently is. Within the udf DEFINE_SPECIFIC_HEAT, there is no way to find the density of the cell of interest, because the udf can not know what the cell of interest is.
It is possible to do a loop over all domains and find out what the average density is (I think a small modification of your code would do about that) but that is not what you want.
What you want is not possible with this udf. I would consider this to be a design flaw of Fluent, but maybe they have a reason for this.
pakk is offline   Reply With Quote
Old   March 6, 2014, 07:57
Gustavo
Thanks, so it is not possible. Are you aware if OpenFOAM (or any other open source CFD code) is able to compute thermophysical (mainly density, conductivity, viscosity and specific heat) properties from the cell's pressure and temperature (or any two other state properties, really)?
What about enthalpy in the DEFINE_SPECIFIC_HEAT, does it pass any kind of information on the cell's enthalpy? Because I could use that to calculate specific heat. But anyways, I am guessing Fluent does not calculate enthalpy as a function of pressure either.
Thanks for your support!
Old   March 6, 2014, 08:27
I don't know about what OpenFoam or other codes can do in this aspect...
Fluent makes the assumption that specific heat is completely determined by temperature (and the mass fractions if you have a mixture). As far as I see, there is no possibility to remove that assumption. Usually, this works fine, although there might be situations (I guess at extremely high pressures?) where the pressure is also relevant.
By the way, you can not use the enthalpy in that UDF to get any information about the cell, because the enthalpy is output of the function, not input. Your udf should also calculate the enthalpy based on the specific heat that it provides.
ghobold likes this.
Old   March 6, 2014, 09:02
Gustavo
That is what I thought.
In my case, the specific heat dependance on pressure is extremely relevant, as I am going to work very close to the critical point, where there's a sudden jump in specific heat with respect to pressure (or density, or any other state property, for that matter).
I will consider coding a CFD code myself for now, at least for some simple geometries.
Old   March 9, 2014, 18:57
François Grégoire
macfly is on a distinguished road
Maybe you could use the DEFINE_PROPERTY macro? I guess you can retrieve cell pressure and temperature within this macro.
macfly is offline   Reply With Quote
Old   March 9, 2014, 20:30
Gustavo
Altough the DEFINE_PROPERTY does retrieve cell information, it is not possible to define specific heat with this macro (when choosing user-defined specific heat in the Materials tab, it is not possible to choose from DEFINE_PROPERTY UDFs).
Old   March 9, 2014, 20:45
François Grégoire
That's a shame. Once again, that kind of problem reflects how it can be complicated to do simple things in Fluent. That's the kind of stuff that takes 5 minutes to figure out in Comsol for example.
Old   June 13, 2017, 13:07
Estêvão Lannes Tolentino
estevaotolentino is on a distinguished road
I'm having a similar problem and I would like to know if this issue has been solved. If so, how was it solved? Thank you.
estevaotolentino is offline   Reply With Quote
Old   August 22, 2019, 00:09
Allen_ayt is on a distinguished road
Hi!
I also came across the same problem, so how did you solve the 'undefined symbol' problem in parallel condition?
Thanks!
Allen_ayt is offline   Reply With Quote
Old   August 22, 2019, 00:36
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
show your code
best regards
AlexanderZ is offline   Reply With Quote
Old   August 22, 2019, 00:42
The code has been deleted.
Old   August 22, 2019, 01:15
Alexander
when did you get this error? are you sure your code is compiled well without errors?
best regards
Old   August 22, 2019, 04:12
The code could be compiled and implemented well on my workstation. However, on the super computer Linux platform, there's an error like this when the EXECUTE_AT_END macro is implemented after the first step calculation.
Thanks!
Old   August 22, 2019, 07:10
Alexander
I have no experience on simulations in Linux. You do better to ask technical support from Ansys
From my point of view, it seems, there are some problems with mpi libraries on linux machine.
Try to remove EXCHANGE_SVAR_MESSAGE_EXT macro and check, how it works.
Frankly speaking, I'm not sure, that you really need it here
best regards
coolprop, fluent, pressure, specific heat, udf
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
