UDF Wall slip velocity
I'm new at the forum and with UDF topic. I'm trying to set a slip velocity at the wall defined by the next function u= beta* du/dn, n being the normal vector to the wall As a first trying I want to solve the problem in a 2D case (flow between two plates) so the equation is u= beta* du/dy, at the wall. I wrote this code but it send me a problem and then fluent is closed. My code is the next one #include"udf.h" DEFINE_PROFILE(mass_fraction_profile, t, i) { real x[ND_ND]; real z; face_t f; begin_f_loop(f,t) { F_CENTROID(x, f, t); z=x[1]; F_PROFILE(f,t,i)= C_DUDZ(F_C0(f,t),t)*0.01; } end_f_loop(f,t) } Any suggest is welcome! |
Hi again,
Please, any help is appreciated! |
fluent has build in slip function, you don;t need to write UDF
best regards |
