November 5, 2019, 17:12 |
udf plasma model
iyad
Rep Power: 6 |
Hi all
i want to apply Shyy and Jayaraman's plasma model actuator on leading edge i dont know how to identify that plasma region in the udf for the equation E=E0-K1x-k2Y. note that the plasma region is a triangular Can someone please tell me how to set a specific point for the applied plasma model? Or atleast locate the exact position of the applied plasma model in the udf thanks Last edited by pitch; November 7, 2019 at 09:08. |
November 7, 2019, 02:47 |
Alexander
Rep Power: 34 |
if you want to get help on UDF! You should specify exactly your problem.
As for me, I don't have time and don't really want to go through papers to find out what do you mean make sketch, show the code you have, explain problems
best regards ****************************** press LIKE if this message was helpful |
November 7, 2019, 05:49 |
iyad
Rep Power: 6 |
thank you for reply
to calculate the electric field E need values X and Y for the formula so the meshes nodes in traingale AOB are indexed by element C_UDMI(c,t,E)=E0-k1*x-k2*y; so my question is how to impose on the mesh variables the zone where there is plasma...and how to index that zoneCapture.JPG Last edited by pitch; November 13, 2019 at 06:26. |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 10:29 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 06:12 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
