UDF for blade displacement
Like Tree8Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
  • 1 Post By vinerm
  • 1 Post By AlexanderZ
  • 1 Post By vinerm
  • 1 Post By vinerm
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   January 29, 2020, 02:12
Default UDF for blade displacement
etedalgara is on a distinguished road
Hi my friends ... I need to write a UDF for a blade displacement ... I should define Phi (as the picture below eq 11) to use it in another formula( as the picture below eq 10), but I can't make a loop over x to define Phi to use it! it is always one number(number 1.695913)!
here is my UDF ...
#include "udf.h"
#define PI 3.141592654
#define ID 3
real xold=0.0;real yold=0.0;
real uold=0.0;real vold=0.0;
real dx=0.0e0;real dy=0.0e0;
real L=0.03;
real Phi;
DEFINE_EXECUTE_AT_END(ForceCalculate)
real Fy=0.0e0;
real x[ND_ND];
real yy;
#if !RP_HOST /* SERIAL or NODE */
real NV_VEC(WS);
real area[ND_ND];
real Fpy = 0.0;
real Fvy=0.0;
Domain *d= Get_Domain(1);
Thread *t=Lookup_Thread(d,ID);
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
yy=x[0];
Phi = 1-sin(((90*PI)/180)*(yy/L));
end_f_loop(f,t);
begin_f_loop(f, t)
if (PRINCIPAL_FACE_P(f,t))
F_AREA(area,f,t);
Fpy+=L*area[1]*F_P(f,t)*Phi;
end_f_loop(f, t)
Fy = Fpy;
#if RP_NODE /* Perform node synchronized actions here*/
Fy=PRF_GRSUM1(Fy);
Fx=PRF_GRSUM1(Fx);
#endif /* RP_NODE */
#endif /* !RP_HOST */
// Message0(" k=%g wd= %g Fy=%g\n",k,wd,Fy);
// Message0(" time=%g xold= %g deltaT=%g\n",time,xold,ts);
node_to_host_real_2(Fy,Fx); /* Does nothing in SERIAL */
#if !RP_NODE /* SERIAL or HOST */
real C=3.69e-6;
real teta=1.38e-9;
real my=7.789e0;
real kyy=3.6;
real ky=kyy+((teta*teta)/C);
real zety=0.0;
real wny=sqrt(ky/my);
real cy=2.0e0*my*wny*zety;
real wdy=wny*sqrt(1.0e0-zety*zety);
real ts=CURRENT_TIMESTEP;
real time=CURRENT_TIME;
real Ay,By,y;
Ay=yold-Fy/ky;
By=(vold+zety*wny*Ay)/wdy;
y=exp(-zety*wny*ts)*(Ay*cos(wdy*ts)+By*sin(wdy*ts))+Fy/ky;
vold=-zety*wny*(y-Fy/ky)+wdy*exp(-zety*wny*ts)*(By*cos(wdy*ts)-Ay*sin(wdy*ts));
dy=y-yold;
yold=y;
FILE *fout;
fout = fopen ("data2D.out","a");
fprintf(fout," %f %f %f %f %f\n",time,yold,Fy,vold,Phi);
fclose(fout);
#endif /* !RP_NODE */
etedalgara is offline   Reply With Quote
Old   January 29, 2020, 07:01
Default Phi is a scalar
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It gives only one value for Phi because Phi is declared as a scalar, i.e., it can store only one number. What you need is a vector that can store as many values of Phi as many x are there. Recommended to use UDM in place of Phi.
etedalgara likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   January 29, 2020, 07:07
Default how can I do?
Thanks for your accountability, since I am poor at writing a UDF and my information is not high, can you correct this for me?
Old   January 29, 2020, 07:10
Default Suggestions
vinerm's Avatar
Vinerm
You should replace Phi with F_UDMI(f, t, 0) everywhere in the code. Along with that you also need to ensure that you enable one UDM in Fluent and initialize by patching it to 0. UDMs are available at UDFs > Memory.
Regards,
Vinerm
Old   January 29, 2020, 07:45
again really Thank you ... to be sure that everything is ok, I want to see the Phi data in **fprintf(fout," %f %f %f %f %f\n",time,yold,Fy,vold,Phi);** as I replace the Phi with F_UDMI(f, t, 0), how can I do it?
Old   January 29, 2020, 07:49
Default Write inside the loop
vinerm's Avatar
Vinerm
Since Phi is not a single value, you have write your output file within the face loop. And as usual, replace Phi with UDM.
Regards,
Vinerm
Old   January 29, 2020, 08:07
my apologies ...
I know I am a bad student!!!
here is my improved UDF: Is it ok?!!!!
#include "udf.h"
#define ID 3
real L=0.03;
real Fy=0.0e0;
real x[ND_ND];
real yy;
real NV_VEC(WS);
real area[ND_ND];
real Fpy = 0.0;
real Fvy=0.0;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
yy=x[0];
F_UDMI(f, t, 0) = 1-sin(((90*PI)/180)*(yy/L));
end_f_loop(f,t);
begin_f_loop(f, t)
F_AREA(area,f,t);
Fpy+=L*area[1]*F_P(f,t)*F_UDMI(f, t, 0);
end_f_loop(f, t)
Fy = Fpy;
Fy=PRF_GRSUM1(Fy);
Fx=PRF_GRSUM1(Fx);
real C=3.69e-6;
real teta=1.38e-9;
real my=7.789e0;
real kyy=3.6;
real zety=0.0;
real Ay,By,y;
Ay=yold-Fy/ky;
dy=y-yold;
yold=y;
FILE *fout;
fprintf(fout," %f %f %f %f %f\n",time,yold,Fy,vold,F_UDMI(f, t, 0));
fclose(fout);
Old   January 30, 2020, 02:08
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
compile code
#include "udf.h"
#define ID 3
real L=0.03;
real Fy=0.0e0;
real x[ND_ND];
real yy;
real C=3.69e-6;
real teta=1.38e-9;
real my=7.789e0;
real kyy=3.6;
real zety=0.0;
real Ay,By,y;
FILE *fout;
real NV_VEC(WS);
real area[ND_ND];
real Fpy = 0.0;
real Fvy=0.0;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
yy=x[0];
end_f_loop(f,t);
begin_f_loop(f, t)
F_AREA(area,f,t);
end_f_loop(f, t)
Fy = Fpy;
#if RP_NODE /* SERIAL or NODE */
Fy=PRF_GRSUM1(Fy);
node_to_host_real_1(Fy); /* Does nothing in SERIAL */
Ay=yold-Fy/ky;
dy=y-yold;
yold=y;
fclose(fout);
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 30, 2020, 03:45
Default Segmentation Violation Expected
vinerm's Avatar
Vinerm
The code that Alexander shared will work for most of the part; I haven't checked it line by line but most likely it will do most of the work, except for writing. You should get Segmentation Violation while writing the output since f does not exist outside begin_f_loop. Therefore, any command making use of f has to be within the loop.
Regards,
Vinerm
Old   January 30, 2020, 04:14
Originally Posted by AlexanderZ View Post
compile code
#include "udf.h"
#define ID 3
real L=0.03;
real Fy=0.0e0;
real x[ND_ND];
real yy;
real C=3.69e-6;
real teta=1.38e-9;
real my=7.789e0;
real kyy=3.6;
real zety=0.0;
real Ay,By,y;
FILE *fout;
real NV_VEC(WS);
real area[ND_ND];
real Fpy = 0.0;
real Fvy=0.0;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
yy=x[0];
end_f_loop(f,t);
begin_f_loop(f, t)
F_AREA(area,f,t);
end_f_loop(f, t)
Fy = Fpy;
Fy=PRF_GRSUM1(Fy);
Ay=yold-Fy/ky;
dy=y-yold;
yold=y;
fclose(fout);
Thank you ... a problem acquired! for *F_UDMI(f, t, 0)* this write 0!
in the links I send you my Mesh, My output Data and my article I am working on! my last Target is to simulate the blade displacement!
http://s7.picofile.com/file/83865613..._yeki.msh.html
http://s6.picofile.com/file/8386561326/data2D.out.html
http://s7.picofile.com/file/83865613...rials.pdf.html
Old   January 30, 2020, 04:21
yeah! this writes the F_UDMI(f, t, 0) by zero, I am really Tired by this! can I have Conversation with you in private! I will send you my article I am working on it! maybe you can help me... this is more than 3 month I am working on this UDF
Old   January 30, 2020, 05:42
Default Not working part
  #12
vinerm's Avatar
Vinerm
Which part of the UDF is not working. About writing I know it will not work but the solution is simple; just do writing within the loop, i.e., move the line with command fprintf before the end_f_loop. Is there any other issue with it?
Regards,
Vinerm
Old   January 30, 2020, 07:53
thank you my friend, the problem loop over x solved!
how can I make a grid motion to simulating the blade displacement?!
with use of the function in the picture:
yt is yold in my code and Phi is F_UDMI(f, t, 0)
Old   January 30, 2020, 08:49
Default Define_grid_motion
  #14
vinerm's Avatar
Vinerm
Look for DEFINE_GRID_MOTION example in UDF manual
Regards,
Vinerm
Old   January 30, 2020, 11:36
thanks ... there is just one question, how can I use *yold* in the *DEFINE_EXECUTE_AT_END* macro to use it in *Grid motion* macro?
Old   January 31, 2020, 03:18
Default Use UDM
  #16
vinerm's Avatar
Vinerm
For all those variables that are varying with space, i.e., functions of their position, it is recommended to use UDM. It appears that yold is also a function of position. Therefore, you should invoke another UDM, and use F_UDMI(f,t,1) to store the value and then use same UDM in GRID_MOTION
Regards,
Vinerm
udf fluent displacement
UDF for vapor pressure anuarun Fluent UDF and Scheme Programming 12 December 24, 2021 10:12
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 02:30
UDF in Fluent Andrew Fluent UDF and Scheme Programming 5 March 7, 2016 03:38
Displacement of particles with an udf Michael Heim FLUENT 0 July 6, 2004 14:08
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
