June 7, 2013, 03:51 |
udf for Roughness Constant, Cs > 1
Samuel
Rep Power: 13 |
Hi, everyone,
I am modeling a domain that has the surrounding area with non-uniform & non-homogenous surface roughness, in which case the surface Roughness Constant, Cs, is outside the upper limit of the range (0.5 - 1.0) that can be specified in Fluent. I desire to specify a value of Cs greater than 1.0 as has been done in previous researches, and this requires udf. Pls., could someone kindly help me with the udf codes for writing constant-value Roughness Constant, Cs. Thanks, and hoping to get a response soon. Samuel. |
October 18, 2013, 12:34 |
Negin Nazarian
Rep Power: 14 |
Hi Samuel,
I was wondering if you have wrote a udf for a wall roughness. I was similar problem and I would appreciate your help. Cheers, Negin |
February 2, 2020, 21:35 |
Ask for UDF code
Kim Min Kyu
Rep Power: 6 |
I've read your post though it's bit old post.
However, it was so challenging because I do not have lots of experiences about both CFD and C++ language coding. If you don't mind me asking, can I get your UDF (User Defined Fucntions) codes? I would like to unlimit wall roughness constant more than 1. (0.5~1.0 as default in FLUENT) I've spending a tremendous time to have homogeneous profile in ANSYS Fluent but all attempts were doomed to failure. I would really appreciate your deep consideration for the beginner who really struggles with ANSYS Fluent's UDF coding. Sincerely, |
February 2, 2020, 23:40 |
Alexander
Rep Power: 34 |
Ansys FLuent Customization manual,
look for DEFINE_PROFILE macro
best regards ****************************** press LIKE if this message was helpful |
Display Modes | |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 06:43 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
Condensation of water if humidity > 100% via UDF | Wikie | Fluent UDF and Scheme Programming | 0 | November 9, 2010 16:41 |
Really big problems when creating own materials da | Jop | FLUENT | 0 | June 28, 2007 11:15 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
