February 16, 2020, 10:35 |
C_YI is returning strange values
Martin
Rep Power: 9 |
edit:
Seems like I messed it up and forgot to change message Output Operators to %f instead %d. I'm sorry, but will Keep it here in case someone stumbles upon the same Problem. Thanks for your Reply. Martin Last edited by 2phase; February 17, 2020 at 12:56. |
February 16, 2020, 16:30 |
Multiple issues
There are multiple issues with the code. h2o_index is undefined. If the code builds and executes that means there are some other sections of the code that are not shown here. But h2o_index is supposed to be a local variable nonetheless. I would expect r_mix to return correct value though. Do you have species modeling enabled in your simulation? If not, then this response is expected.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
How can values of profile(k, epsilon) not change? | minque | FLUENT | 4 | January 22, 2020 14:14 |
Loading Cell Values in Tecplot | P1361 | OpenFOAM Post-Processing | 3 | September 16, 2014 04:02 |
Strange values in drag coefficient of a fuselage | Victor31 | FLUENT | 5 | May 14, 2014 11:30 |
cell values vs node values | reversemermaid | FLUENT | 0 | March 13, 2014 18:06 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
