February 14, 2020, 08:19 |
Accessing total enthalpy values in a UDF
Nithin
Rep Power: 6 |
I am trying to obtain total enthalpy values of my finite rate combustion simulations. I tried using the C_H(c,t) macro, but it retrieves sensible enthalpy values and not total enthalpy values. How do I access the total enthalpy values, either through some computation within the UDF or through a macro?
( if it is even possible) |
February 14, 2020, 13:06 |
Enthalpy of Formation
You may have to add enthalpy of formation to that. You can use PROP_href or PROP_hform to fetch this within a UDF. Look at UDF example that uses species loop.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
The total enthalpy of a radial turbine | Ahmed Saeed Mansour | CFX | 2 | February 13, 2017 11:28 |
UDF for reading velocity values and adding random perturbation | Jomid | Fluent UDF and Scheme Programming | 0 | October 2, 2016 00:46 |
UDF gives different values than calculated manually | RebeccaKn92 | Fluent UDF and Scheme Programming | 4 | February 6, 2016 11:29 |
Problem with a simple UDF to calculate cell-averaged particle values | kmayank | FLUENT | 1 | January 18, 2011 01:40 |
Availability of previous time level values in UDF | ranga sudarsan | FLUENT | 0 | September 1, 2008 09:17 |
