March 31, 2020, 19:03 |
3D UDF for rectangular domain inlet
AL AMEEN AHMED RUFAI
Hi, I am trying to model a UDF for my wind tunnel inlet using power law.
1; when I try computing my inlet conditions from in reference value I get *nan* in velocity section (#include "udf.h" #define P 1./7. //power law n value 7// #define uref 1.32 // m higeht of inlet// DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real z; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); z = x[2]; F_PROFILE(f, thread, position) = 40*pow(z/uref,P); } end_f_loop(f, thread) } 2; I get the same issue and error when I try using the function expression. uref [m s^-1] * (z / z_ref [m]) ** alpha3.my inlet is at x=-1 using magnitude and direction under velocity specification method Last edited by aar007; March 31, 2020 at 19:06. Reason: additional information |
April 1, 2020, 03:10 |
Udf
The UDF is alright and you can use it. However, this cannot be used for initialization. DEFINE_PROFILE is not executed before initialization. You have to initialize by providing some value for the velocity.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 11, 2022, 07:06 |
Ved prakash
Hi, have you found the solution?? I am also trying to use this expression. Please help me out.
May 11, 2022, 22:58 |
Alexander
Rep Power: 34 |
solution is written by vinerm one line above
best regards ****************************** press LIKE if this message was helpful |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
Ansys Fluent UDF, Wall Average Temperature Depend On Inlet Velocity | ozgeozge | Fluent UDF and Scheme Programming | 1 | April 15, 2019 01:31 |
Fluent UDF wrong number of cells in parallel - correct in serial | dralexpe | Fluent UDF and Scheme Programming | 7 | May 17, 2018 08:26 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Reduced domain/ Pressure inlet to velocity inlet | victoryv | FLUENT | 1 | June 29, 2013 14:45 |
