April 12, 2020, 01:25 |
surface tension equation as source term
Ghazi
Rep Power: 6 |
Hi everyone,
I want to write a UDF for the surface tension equation(source term in the momentum equation of the VOF model ) as the attached file. Can anyone help me with that? |
April 13, 2020, 04:27 |
Surface Tension
What is the objective behind writing this UDF? Both, CSF and CSS, models for surface tension force modeling are available as inbuilt models in Fluent.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 13, 2020, 04:53 |
#3 | |
Ghazi
Rep Power: 6 |
I tried to simulate steam condensation phenomena inside a tube, I came to know from different literature that existing modules of ANSYS FLUENT are not well versed to model two-phase flow simulation i.e. specifically when it comes to steam [properties & state both varies with process parameters], therefore, I activated the source terms in mass and energy equation, and I want to activate the surface tension force in the momentum equation to the VOF modeling to straightforward my work. Greetings MohammedGhazi |
April 13, 2020, 06:11 |
Udf
Surface tensions models are meant for only multiphase flows; single phase does not have a surface, consequently no surface tension or its requirement for modeling
Anyway, if you want to include source term, then you need to use DEFINE_SOURCE macro. Look at the following for the examples https://www.afs.enea.it/project/nept...udf/node49.htm Since the source needs to be applied only at the free surface, you need to check for the cells containing free surface, i.e., cells with C_VOF for any of the phases between some acceptable values, say, between 0.3 and 0.7. A more sophisticated approach is to check for its gradient to identify the cells containing the free surface but checking the value of C_VOF also works good. And then, just apply the source term in the cells matching the criterion.
March 23, 2021, 21:00 |
#5 | |
Venkat Ganesh
Rep Power: 5 |
surface tension, udf, vof modeling |
Source Term due to evaporation in energy transport equation | styleworker | OpenFOAM Programming & Development | 3 | September 7, 2022 03:09 |
How to add Source term (2) for PYROLYSIS - reactingOneDim | Kummi | OpenFOAM | 10 | April 12, 2021 21:11 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
Source term for EVAPORATION in Energy Equ. - technical difficulty ? | Kummi | OpenFOAM | 1 | September 9, 2019 09:32 |
