UDF Double Precision Error?
Like Tree1Likes
  • 1 Post By vinerm
Old   April 20, 2020, 16:24
Default UDF Double Precision Error?
j
buckngnr11 is on a distinguished road
Probably a dumb question. I'm using a double precision solver, and using a UDF to make various calculations. When I display the output of the calculations in the console I notice that some of the variables appear to have a floating point error (values are on order E+200). The variable being calculated here involves no division, just multiplying two very small numbers (1e-8 and another of order 1e-9). I suspect that I'm having a precision error. I'm assigning all variables to be type real. Not sure what my options are to remedy this other than hardcoding any large numbers to zero. I'd rather have a more elegant solution since I'm not entirely positive this is necessarily the issue.
buckngnr11 is offline   Reply With Quote
Old   April 20, 2020, 16:37
Default Double Precision
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
As far as double precision is concerned, it is machine dependent. However, 1e-8 or 1e-9 is quite large as compared to machine precision if you are using double precision. So, these should be treated properly as finite numbers without any issue. However, it matters for what parameter in Fluent are you using these numbers. E.g., there are certain limits set in Fluent, which could be changed by user, if required, that do not allow numbers to be smaller than a certain limit. If you are using single precision, then certainly these numbers will be treated as 0. Also note that in UDF, use 1.e-9 and not 1e-9.
buckngnr11 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 21, 2020, 04:24
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
how do you display your variables?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
blowing up, double precision, error
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 02:03
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 10:38
