j
Rep Power: 0 ![]() |
Question related to a previous thread. In my UDF, I set three UDM values for the x y and z components of the face normals on the mesh. After running the executable, I can plot each UDM on the boundaries and they all work and display as expected. Now, when I add a line of code in my UDF calling this UDM and run the executable again, I get a segmentation error. Like I said the UDM is created fine, so I'm not sure why calling it into a new variable would be an issue. I'm also running in parallel, but I'm using the correct RP functions. Any ideas?
Try plotting the values for the UDMs. Secondly, as suggested earlier, try averaging using some dummy number for facecount.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Display Modes | |
DPM, access particle data - number of tries | wsaac | Fluent UDF and Scheme Programming | 1 | July 31, 2018 02:40 |
Convergence issue in natural convection problem | chrisf90 | FLUENT | 5 | March 5, 2016 08:30 |
Is there a way to access the gradient limiter in Fluent ? | CFDYourself | FLUENT | 1 | February 16, 2016 05:49 |
access violation in Fluent 6.3 | behest | Fluent UDF and Scheme Programming | 2 | March 24, 2014 09:58 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 08:27 |
