UDF - Question
Old   May 8, 2020, 10:10
Default UDF - Question
sandy
archeoptyrx is on a distinguished road
Hi i am trying to understand the define grid motion udf given in the manual.
Can someone explain what is 0.230 "pow (NODE_X(v)/0.230, 0.5)" doing here ? . Why do we want to divide the node x by that number ?
node motion based on simple beam deflection equation
compiled UDF
#include "udf.h"
DEFINE_GRID_MOTION(beam,domain,dt,time,dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real NV_VEC(omega), NV_VEC(axis), NV_VEC(dx);
real NV_VEC(origin), NV_VEC(rvec);
real sign;
int n;
/* set deforming flag on adjacent cell zone */
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
sign = -5.0 * sin (26.178 * time);
Message ("time = %f, omega = %f\n", time, sign);
NV_S(omega, =, 0.0);
NV_D(axis, =, 0.0, 1.0, 0.0);
NV_D(origin, =, 0.0, 0.0, 0.152);
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
/* update node if x position is greater than 0.02
and that the current node has not been previously
visited when looping through previous faces */
if (NODE_X(v) > 0.020 && NODE_POS_NEED_UPDATE (v))
/* indicate that node position has been update
so that it's not updated more than once */
NODE_POS_UPDATED(v);
omega[1] = sign * pow (NODE_X(v)/0.230, 0.5);
NV_VV(rvec, =, NODE_COORD(v), -, origin);
NV_CROSS(dx, omega, rvec);
NV_S(dx, *=, dtime);
NV_V(NODE_COORD(v), +=, dx);
end_f_loop(f,tf);
archeoptyrx is offline   Reply With Quote
Old   May 8, 2020, 12:21
Default Equation
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
That's just an equation for a cantilever motion. You would anyway use your own equation.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared on the Forum
vinerm is online now   Reply With Quote
Old   May 8, 2020, 15:37
sandy
Thanks Vinerm.
question on udf melj FLUENT 10 February 12, 2020 12:49
A general question on using UDF for defining reaction kinetics Morijef Fluent UDF and Scheme Programming 0 September 19, 2018 15:37
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 07:26
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
UDF question Meghesh FLUENT 1 November 2, 2004 08:24
