How to let UDF run in parallel
Old   May 10, 2020, 09:37
Default How to let UDF run in parallel
mariam.sara is on a distinguished road
Hello I have the below UDF for mixture density it works fine in series I want to run it in parallel what changes I need to add.
include "udf.h"
DEFINE_PROPERTY(c_densityN10RaT1E6, c, t)
real rhm,rho,To,Co,betaT,betaC;
real T = C_T(c,t);
rho= 1.12;
Co=0.049;
To=313.15;
betaT=0.0032;
betaC=0.590636677;
rhm = rho*(1.-betaT*(T-To)-betaC*(1.*C_YI(c,t,0)-Co)); /* density of mixture */
return rhm;
Thanks
Mariam
mariam.sara is offline   Reply With Quote
Old   May 10, 2020, 12:20
Default Parallelization
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Usually, such code do not require parallelization. However, you can do that just to be sure.
Put whole of the code within
#if !RP_HOST
#endif
#if must be after opening brace of the DEFINE_ function and #endif before the the closing brace.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared on the Forum
vinerm is online now   Reply With Quote
Old   May 10, 2020, 16:16
Many thanks Vinerm to the reply. Is that used normally with interpret option or I need to use compile when using parallel?
Mariam
#if !RP_HOST
#endif
Old   May 11, 2020, 03:15
vinerm's Avatar
Vinerm
Compilation or Interpretation are not related to parallelization. So, if you are using the code for parallel simulation, you should parallelize it, doesn't matter whether you compile or interpret.
Regards,
Vinerm
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Error code: 126 when loading parallel UDF Coop Fluent UDF and Scheme Programming 0 July 13, 2018 08:33
parallel run is slower than serial run (pimpleFoam) !!! mechy OpenFOAM 18 August 17, 2016 17:19
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 13:53
