June 17, 2019, 08:56 |
sinusoidal rotation UDF
Ki Jong Kim
Rep Power: 7 |
now i am trying to simulate the sinusoidal rotation of the cylindrical tank with below conditions. -Amplitude: 50deg (0.872 rad) -frequency: 0.125 hz (=period: 8sec) The tank will be simulating with Y axis and there is no transitional movements. The code what i did is, #include "udf.h" DEFINE_ZONE_MOTION(rotation,omega,axis,origin,velo city,time,dtime) { *omega[0] = 0.0; *omega[1] = 2*3.141592*0.125*0.872*cos(2*3.141592*0.125*time); *omega[2] = 0.0; N3V_D (velocity,=,0.0,0.0,0.0); N3V_D (omega,=,0.0,1.0,0.0); return; } but i returns error message like below, ..\..\src\rotation_test_17.c(5) : error C2100: illegal indirection ..\..\src\rotation_test_17.c(6) : error C2100: illegal indirection ..\..\src\rotation_test_17.c(7) : error C2100: illegal indirection Anyone who can help me modify the code or any comments? (Please help me...) It would be very help and thank you so much in advance. Best regards, Denis |
June 18, 2019, 01:19 |
Alexander
Rep Power: 34 |
omega is a scalar,
you have to define origin and axis Ansys Fluent Customization manual -> DEFINE_ZONE_MOTION best regards |
June 18, 2019, 06:01 |
Ki Jong Kim
Rep Power: 7 |
Thank you for your valuable comments.
i am recoding in consideration of your comments. can you give me a comments below UDF? #include "udf.h" DEFINE_ZONE_MOTION(rotation,omega,axis,origin,velo city,time,dtime) { *omega = 2*3.141592*0.125*0.872*cos(2*3.141592*0.125*time); N3V_S(origin,=,0.0); /* default values, line could be omitted */ N3V_D(axis,=,0.0,1.0,0.0); /* default values, line could be omitted */ return; } Thank you in advance. Best regards, Kim |
June 19, 2019, 00:08 |
Alexander
Rep Power: 34 |
very good code,
try it best regards |
June 19, 2019, 00:13 |
Ki Jong Kim
Rep Power: 7 |
very thanks@@!
It works!! Best wishes, Denis |
May 19, 2020, 13:10 |
problem in my DEFINE_ZONE_MOTION UDF
mohammad
Rep Power: 6 |
hi i have a problem with my code in mesh motion rotation.i have a fuel assembly and i should simulate heaving and rolling motions. my code its in below:
#include<udf.h> #define period 6 #define angular_freq 2*M_PI*period #define tetamax 10*M_PI/180 DEFINE_ZONE_MOTION(fmotion,omega,axis,origin,veloc ity,time,dtime) { *omega =tetamax*sin(angular_freq*time); N3V_D (velocity,=,0.0,0.0,0.0); N3V_S(origin,=,0.0); N3V_D(axis,=,1.0,0.0,0.0); return; } i need my geometry rotate between -10 and 10 degree but with this code my geo rotate between 0 and 10 degre what's my problem? thank's |
May 19, 2020, 15:25 |
Angular Frequency
That's because the angular frequency is wrong. Divide it by 180.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 20, 2020, 18:03 |
mohammad
Rep Power: 6 |
May 21, 2020, 07:49 |
Angular Frequency
#9 |
You are right. You don't really need that and it actually changes nothing except reducing the rotational speed. But if 6 is really the time period then your equation for angular frequency is wrong. It should be . And with that, you get one complete cycle within 6 seconds, including -0.1745 as minimum value, which corresponds to -10 in degree.
May 22, 2020, 17:39 |
#10 |
mohammad
Rep Power: 6 |
UDF Rotation | lepetitmort | Fluent UDF and Scheme Programming | 38 | October 15, 2020 06:29 |
udf for blade rotation | mamad7192 | Fluent UDF and Scheme Programming | 1 | May 28, 2017 17:09 |
UDF for non sinusoidal or varying amplitude motion with respect to time | lalit kumar | FLUENT | 1 | November 13, 2010 16:58 |
Sinusoidal motion udf | urmazda | Fluent UDF and Scheme Programming | 6 | July 30, 2010 11:44 |
VOF UDF FOR PATCHING SINUSOIDAL FREE SURFACE | beginner | FLUENT | 1 | September 10, 2007 02:16 |
