Excessive condensation UDF causes temperature field and pressure field disorder
Hello Everyone,
I am trying to use the udf code to simulate in-tube condensation of the steam and air mixture.The VOF model and the species transport model were enabled in Fluent. A liquid phase mass source term, a gas phase mass source term, and an energy source term are defined. My idea is to judge whether it is a vapor-liquid interface firstly, if it is, then assign a value to the source term, if not, then continue to judge whether it is a wall surface. The thickness of the first layer of my adherent mesh is 0.03mm. When the The value of the source term is small , 2.56e-4 for example , temperature field and pressure field are normal , but when the value is high , 4000 for example, the temperature field and pressure field are strange . My wall temper is 300K, and inlet gas temper is 373.5K,but after running for several steps , the static temper is as high as 590K. My initial static pressure is 0, after running , the pressure is 2.69e9 . Anybody know why that is? #include "udf.h" #include "sg.h" #include "sg_mphase.h" #include "flow.h" #include "mem.h" #define air_molecular 28.966 #define vapor_molecular 18.0152 #define lam 0.8 #define standard_temper 298.15 #define standard_pressure 101325 #define standard_diffusivity 2.56e-5 #define SYMMETRY 13 #define WALL_NUMBER1 12 #define prim_index 0 #define index_evap_primary 1 #define p_op 101325 int phase_domain_index; real face_center[ND_ND], cell_center[ND_ND], a[ND_ND], b[ND_ND]; real p, diffusivity, Wvol; real cell_vapor_pressure, wall_temper, wall_pressure; real NV_VEC(A),j,i; real area, area_density, mass_transfer_coeff, B1, area1; real water_temper, water_satpressure; real vapor_density,u,v; int n; Domain *domain1; cell_t c; Thread *t; Thread *tp; Thread *ts; Thread *tf,*tb; face_t fa; face_t fb ; real source; double latent_heat(double Tsat) { double sum; sum=2501.7-2.4114*(Tsat-273.15); return sum; } DEFINE_SOURCE(vap_src,cell,first,dS,eqn) { Thread *mixer, *sec_th; Thread *sym; face_t f; real m_dot_first; real mass_dot; mixer = THREAD_SUPER_THREAD(first); sec_th = THREAD_SUB_THREAD(mixer,1); if (C_VOF(cell, first) > 0&&C_VOF(cell, first) < 1) { mass_dot = -2.56e-4; dS[eqn] =0; } else { mass_dot =0; dS[eqn]=0; c_face_loop(cell, mixer, n) { fa = C_FACE(cell, mixer, n); tf = C_FACE_THREAD(cell, mixer, n); F_CENTROID(face_center, fa, tf); if (face_center[0] < 1e-5) { mass_dot = -2.56e-4; dS[eqn] =0; } } } source = mass_dot; return source; } DEFINE_SOURCE(liq_src, cell, sec_th, dS, eqn) { Thread *mixer, *first; Thread *sym; face_t f; real mass_dot; mixer = THREAD_SUPER_THREAD(sec_th); first = THREAD_SUB_THREAD(mixer, 0); if (C_VOF(cell, sec_th) > 0&&C_VOF(cell, sec_th) < 1) { mass_dot = 2.56e-4; dS[eqn] =0; } else { mass_dot =0; dS[eqn]=0; c_face_loop(cell, mixer, n) { fa = C_FACE(cell, mixer, n); tf = C_FACE_THREAD(cell, mixer, n); F_CENTROID(face_center, fa, tf); if (face_center[0]< 1e-5) { mass_dot = 2.56e-4; dS[eqn] =0; } } } source = mass_dot; return source; } DEFINE_SOURCE(enrg_src, cell, mixer, dS, eqn) { Thread *first, *sec_th; Thread *sym; face_t f ; real m_dot, latentheat; real mass_dot; first = THREAD_SUB_THREAD(mixer, 0); sec_th = THREAD_SUB_THREAD(mixer, 1); /************************************************/ if (C_VOF(cell, sec_th) > 0&&C_VOF(cell, sec_th) < 1) { mass_dot = -2.56e-4; dS[eqn] =0; } else { latentheat = latent_heat(C_T(cell, first)); mass_dot =0; dS[eqn]=0; c_face_loop(cell, mixer, n) { fa = C_FACE(cell, mixer, n); tf = C_FACE_THREAD(cell, mixer, n); F_CENTROID(face_center, fa, tf); if (face_center[0] < 1e-5) { mass_dot = -2.56e-4; dS[eqn] =0; } } } m_dot = -mass_dot; return latentheat*m_dot; } |
Source
Source values have a limit; larger source values make the coefficient matrix non-diagonal dominant, which leads to convergence issues. If the source values are expected to be high, then use coarser mesh.
