Question about using Macro F_FLUX(f,t)
1 Attachment(s)
Hello everybody,
I want to implement an equation (governing equation of flow in porous media) which is very similar to Navier-Stokes equation, in ansys fluent. I have attached a photo of the equation. As can be seen from the photo i need to change the convective term. In fact the convective term is multiplied by a constant (1/phi^2 phi is porosity). I think the appropriate macro is F_FLUX(f,t) and i also wrote UDF to do that however after compiling the UDF i receive fatal signal (segmentation fault). Below is the UDF i have developed. It would be highly appreciate if anyone helps me to fix this problem. #include "udf.h" #include "mem.h" #include "math.h" DEFINE_ADJUST(set_convective_flux, d) { real porosity = 0.95; Thread *t; cell_t c; face_t f; thread_loop_c(t,d) { begin_c_loop(c,t) { thread_loop_f(t,d) { begin_f_loop(f,t) { F_FLUX(f,t) = F_FLUX(f,t)/(porosity*porosity); } end_f_loop(t, d) } } end_c_loop(c,t) } } |
Loop
That's because you are using two loops. You don't need two outermost loops. Just thread_loop_f and begin_f_loop.
However, there are other problems with the code. You can looping over all the boundaries, while F_FLUX exists only for openings, such as, inlet, outlet, etc. |
F_flux
The function exists irrespective of the condition. What I meant is that the fluxes will have a non-zero value only for the openings. Of course, you wouldn't expect fluxes for the walls or symmetry. Periodic conditions on the other hand will have fluxes and so does the interior. But, it would still be better to call this function only on openings.
You're right. The fluxes will have a non-zero value only for the openings but i think convective flux of each internal face is not zero. That's why i loop over all faces(internal and external) to change convective flux to implement the equation. I guess this is the only way to manipulate convective terms of Navier-Stokes equations in ansys fluent.
