Velocity Sampling in parallel simulation
Old   July 19, 2020, 05:09
Post Velocity Sampling in parallel simulation
YUNPENG SONG
Torii_Nagi is on a distinguished road
I meet some problem in velocity sampling by looping all cells.
Actually, my target is to get the velocity alone 3 moving lines in every time steps. And then sampled velocity will been used in source term calculation.
To achieve my target, I use cell loop in ADJUST marco trying to get the velocity of the cell closest to my target point alone 3 lines. To store those velocity for next calculation, I created 3 2D-arrays(Global variable).
To my understanding, by approaching cell loop and thread loop, I can access the velocity of each cell in the entire domain, so that I can store the value which satisfy my requirement in defined global variable.
However, the results shows that the 2D-arrays have different values in different NODE. I think there may have some communication issue between each nodes.
It seems that each NODE has a global variable with the same name but store different value.
Is there any better way that I can achieve my target?
Here shows my UDF code.
#include "udf.h"
#include <math.h>
/* Wind Turbine Parameters ============================*/
#define B_NUM 3	  /* number of the blades;  */
#define RPM 15    /* rotation speed of blade (round per minute)*/
/* Projection Parameters ==============================*/
#define rot_x 5.0 /* thickness of the rotor disk*/
/* Velocity Sampling Parameters =======================*/
#define S_R 55.0  /* Sampling radius  */
#define SS_NUM 30 /* Sampling Section number */
/* Other Parameters ===================================*/
#define pi 3.141592653
/* Define Golable Variables ==========================*/
real Ux_bld[B_NUM][SS_NUM]; /* x velocity alone blade [empty]*/
real Uy_bld[B_NUM][SS_NUM]; /* y velocity alone blade [empty]*/
real Uz_bld[B_NUM][SS_NUM]; /* z velocity alone blade [empty]*/
real d_bld[B_NUM][SS_NUM];	/* r of earch point alone blade [empty]*/
real nearest_d[B_NUM][SS_NUM]; /* nearest distence [empty]*/
real azimuthAngle[B_NUM]; /* azimuthAngle [empty]*/
real roundCount;		  /* roundCount [empty]*/
DEFINE_INIT(initialization, d)
#if !RP_HOST
	/* velocity Initialization */
	real point_interval = S_R / SS_NUM;
	int i, j;
	for (i = 0; i < B_NUM; i++)
		for (j = 0; j < SS_NUM; j++)
			d_bld[i][j] = (j + 1) * point_interval;  /*  Initialize the radius of earch point */
			Ux_bld[i][j] = -2; /* velocity Initialization */
			Uy_bld[i][j] = -2; /* velocity Initialization */
			Uz_bld[i][j] = -2; /* velocity Initialization */
#endif
DEFINE_ADJUST(blade_velocity, d)
#if !RP_HOST
	int partitions, ids = myid;
	partitions = PRF_GIHIGH1(ids) + 1; /* Obtain the numbers of NODEs */
	Thread *t;
	cell_t c;
	int i, j, p;
	real x0 = 0, y0 = 0, z0 = 114.25;
	real flow_time = RP_Get_Real("flow-time"); /* obtain current time from Fluent */
	real Omega = RPM * 2 * pi / 60;			   /* rotational speed (rad/s) */
	real xyz[3], x, y, z, r;
	real x_c, y_c, z_c, DITS;
	/* Update Blades azimuthAngle */
        /* azimuthAngle calculation */
		azimuthAngle[i] = (0.0 + i * 120) * (pi / 180.0) + Omega * flow_time;
		roundCount = azimuthAngle[i] / (2 * pi);
		azimuthAngle[i] = azimuthAngle[i] - floor(roundCount) * (2 * pi);
			/* Initialize the nearest distence Matrix */
			nearest_d[i][j] = 9999999;
	for (p = 0; p <= partitions - 1; p++)
		if (p == myid)
			Message("\n >> | MYID: %d | \n", p);
			thread_loop_c(t, d)
				begin_c_loop(c, t)
					C_CENTROID(xyz, c, t);
					x = xyz[0];
					y = xyz[1];
					z = xyz[2];
					r = sqrt(pow(x - x0, 2) + pow(y - y0, 2) + pow(z - z0, 2));
					if (r <= S_R && (x - x0) >= -rot_x && (x - x0) <= rot_x)
								x_c = 0 + x0; /* Calculate point coordinate of x */
								y_c = cos(azimuthAngle[i]) * d_bld[i][j] + y0; /* Calculate point coordinate of y */
								z_c = sin(azimuthAngle[i]) * d_bld[i][j] + z0; /* Calculate point coordinate of z */
								DITS = sqrt(pow(x - x_c, 2) + pow(y - y_c, 2) + pow(z - z_c, 2)); /* calculate distence between cell and target point */
								if (DITS < nearest_d[i][j])  /* find nearest cell */
									/* nearest local velocity */
									Ux_bld[i][j] = C_U(c, t);
									Uy_bld[i][j] = C_V(c, t);
									Uz_bld[i][j] = C_W(c, t);
									nearest_d[i][j] = DITS;
									/*Message("\n | Point Radius: %f m  | Nearest DIST : %f m | Velocity < x: %f m/s  y: %f m/s z:%f m/s > | \n" ,d_bld[i][j], nearest_d[i][j], Ux_bld[i][j], Uy_bld[i][j], Uz_bld[i][j]);*/
				end_c_loop(c, t)
			Message("\n ============================ >> I AM: %d  START<< =================================== \n", myid);
				Message("\n | BLADE: #%d | Nearest DIST : %f m |  Point Radius: %f m  | Point Velocity < x: %f m/s   y: %f m/s   z: %f m/s > \n", 1, nearest_d[1][j], d_bld[1][j], Ux_bld[1][j], Uy_bld[1][j], Uz_bld[1][j]);
			Message("\n ============================ >> I AM: %d  END << =================================== \n", myid);
		PRF_GSYNC();
#endif
For debug, I also attached a screenshot of message in Fluent console(which only shows part of the output). You can find that the results in different node is not the same, and for some nodes, the value is still remain initialized one.
Last edited by Torii_Nagi; July 19, 2020 at 12:20. Reason: missed some key information
Torii_Nagi is offline   Reply With Quote
Old   July 20, 2020, 01:29
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
by default fluent partitioning is random. So your curve may not be in partition 1 and 2 (from your picture) It could be the reason of this outcome
each computational node calculates on separated part of domain
but frankly, I didn't get how your code works
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
global variable, parallel calculation
Fluent simulation in parallel is slower on workstation than laptop?!!?! losiola ANSYS 5 November 4, 2022 08:56
OpenFoam: time averaging velocity of a URANS Simulation andreic OpenFOAM Post-Processing 1 August 22, 2019 09:40
OpenMPI error at the beginnin of parallel OpenFOAM Simulation tre95 OpenFOAM Programming & Development 2 June 17, 2019 06:36
How to set unsteady turbulent inlet velocity using the result of another simulation? John-Lee FLUENT 2 December 27, 2016 17:36
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
