On the UDS flux
I currently conduct a steady-state simulation for the velocity and (passive) scalar fields. In calculating scalar field, we should specify flux function in 'user-defined/scalars'. Here, I don't understand the difference between the 'mass flow rate' flux function (given by fluent) and a 'DEFINE_UDS_FLUX' (provided by udf manual, see below). I conducted simulations with both flux functions and found that the results are different. The following is the code of 'DEFINE_UDS_FLUX' in udf manual: (https://www.afs.enea.it/project/nept...udf/node90.htm) /************************************************** ********************/ /* UDF that implements a simplified advective term in the */ /* scalar transport equation */ /************************************************** ********************/ #include "udf.h" DEFINE_UDS_FLUX(my_uds_flux,f,t,i) { cell_t c0, c1 = -1; Thread *t0, *t1 = NULL; real NV_VEC(psi_vec), NV_VEC(A), flux = 0.0; c0 = F_C0(f,t); t0 = F_C0_THREAD(f,t); F_AREA(A, f, t); /* If face lies at domain boundary, use face values; */ /* If face lies IN the domain, use average of adjacent cells. */ if (BOUNDARY_FACE_THREAD_P(t)) /*Most face values will be available*/ { real dens; /* Depending on its BC, density may not be set on face thread*/ if (NNULLP(THREAD_STORAGE(t,SV_DENSITY))) dens = F_R(f,t); /* Set dens to face value if available */ else dens = C_R(c0,t0); /* else, set dens to cell value */ NV_DS(psi_vec, =, F_U(f,t), F_V(f,t), F_W(f,t), *, dens); flux = NV_DOT(psi_vec, A); /* flux through Face */ } else { c1 = F_C1(f,t); /* Get cell on other side of face */ t1 = F_C1_THREAD(f,t); NV_DS(psi_vec, =, C_U(c0,t0),C_V(c0,t0),C_W(c0,t0),*,C_R(c0,t0)); NV_DS(psi_vec, +=, C_U(c1,t1),C_V(c1,t1),C_W(c1,t1),*,C_R(c1,t1)); flux = NV_DOT(psi_vec, A)/2.0; /* Average flux through face */ } /* ANSYS FLUENT will multiply the returned value by phi_f (the scalar's value at the face) to get the "complete'' advective term. */ return flux; } I think the above code also returns mass flow rate (rho*u*A), and thus I expected that the results should be identical. But I don't understand why the results are different each other. I really appreciate if you give an answer. Best regards, |
Same issue
I have had the same issues (in a 2D axisymmetric case). Did you find the solution for it?
