Distinguish particles injected from Injection |
October 23, 2020, 12:17 |
L.A.Isanka
Rep Power: 5 |
Hello!
I'm working on a model to separate microparticles based on dipole interaction forces. Heterogeneous microspheres are injected using 2 injections, injection 0 & injection 1. Do you know of a method to distinguish between particles injected from these injections. Injected particles from both injections are identical except for their surface properties and I'm using dipole interactions to separate the particles injected via the two injections. The interaction force is different for the two injections. Thus, once a particle is located, I want to identify whether it is from injection 0 or injection 1. Cant use DEFINE_DPM_INJECTION_INIT macro since I'm using DPM_BODYFORCE macro and cant insert DEFINE_DPM_INJECTION_INIT macro inside that. I'd be grateful if you could help me with this. Thank you! |
dpm in fluent, fluent udf, injection, interactions |
how to determine the number of particles injected. | welch | FLUENT | 2 | January 18, 2024 04:08 |
Fluent UDF - Distinguish particles from two different injections | Achini | Main CFD Forum | 0 | October 12, 2020 11:02 |
file injection.: continuity fail; volume injection.: wrong total mass | blerli_91 | Fluent Multiphase | 6 | October 2, 2018 05:34 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
