November 24, 2020, 07:25 |
SIGSEGV error when running UDF
Tyler Richardson
Rep Power: 8 |
I'm trying to calculate the heat transfer coefficient at the interface between my solid and fluid mesh (simple pipe, CHT) The following code seems to fail every time with a SIGSEGV error. In fact, it wont even print out my messages within begin_f_loop. The output i get is "Begin F loop" (as i message out), and then the SIGSEGV error. I originally thought this was due to trying to loop along some solid faces, so i put a little if statement to omit any threads other than the one i am interested in. I am totally lost. any help would be greatly appreciated. Thanks! Code:
#include "udf.h" #include "sg.h" #include "mem.h" DEFINE_ON_DEMAND(on_demand_calc) { /* Initialize face data */ real kt, dTx, dTy, dTxRG, dTyRG, dTr, dTrRG; /* Initialize heat Transfer Coefficient*/ real whtc, whtcRG; /* Initialize Temp, Q */ real TWall, TBulk, QWall, QWallRG, TWadj; Domain *d; /* declare domain pointer since it is not passed as an argument to the DEFINE macro */ Thread *t, *t0; cell_t c0; face_t f; d = Get_Domain(1); /* Loop over all boundary zones in the domain */ thread_loop_f(t,d) { Message ("Cell Thread %d \n", t); Message (THREAD_NAME(t)); if (strcmp(THREAD_NAME(t),"pipe_fluid")!=0) { Message ("skipping thread \n"); continue; /* break; */ } /* function that returns TRUE if Thread *t is a boundary face thread */ if (BOUNDARY_FACE_THREAD_P(t)) /* (WALL_THREAD_P(t))*/ { Message ("Begin F loop \n"); /* Loop over all faces */ begin_f_loop(f,t) { if (f==0) { Message ("Beginning face loop \n"); } /* c0 and t0 identify the adjacent cell */ c0 = F_C0(f, t); t0 = THREAD_T0(t); /* Properties */ kt = C_K_L(c0,t0); Message ("kt = %g \n",kt); /* Cell Gradients */ dTx = C_T_G(c0,t0)[0]; /* returns the x-component of the cell temperature gradient vector */ dTy = C_T_G(c0,t0)[1]; /* returns the x-component of the cell temperature gradient vector */ Message ("dTx = %g \n",dTx); Message ("dTy = %g \n",dTy); dTxRG = C_T_RG(c0,t0)[0]; /* returns the x-component of the cell temperature gradient vector */ dTyRG = C_T_RG(c0,t0)[1]; /* returns the x-component of the cell temperature gradient vector */ Message ("dTxRG = %g \n",dTxRG); Message ("dTyRG = %g \n",dTyRG); dTr = pow(pow(dTx,2)+pow(dTy,2),0.5); dTrRG = pow(pow(dTxRG,2)+pow(dTyRG,2),0.5); Message ("dTr = %g \n", dTr); Message ("dTrRG = %g \n",dTrRG); QWall = -kt*dTr; QWallRG = -kt*dTrRG; Message ("Qwall = %g \n", QWall); Message ("QwallRG = %g \n",QWallRG); /* Retrieve bulk temperature & Wall Adjacent Temperature */ TBulk = RP_Get_Real("ref/temperature"); TWadj = F_T(f,t); Message ("TBulk = %g \n",TBulk); Message ("TWadj = %g \n",TWadj); /* Calculate heat transfer coefficient */ whtc = QWall/(TWadj-TBulk); whtcRG = QWallRG/(TWadj/TBulk); /* TWall = QWall/(-kt*dTr) + TWadj */ Message ("Store data \n"); C_UDMI(c0,t0,0) = whtc; F_UDMI(f,t,0) = whtc; C_UDMI(c0,t0,1) = QWall; F_UDMI(f,t,1) = QWall; C_UDMI(c0,t0,2) = QWallRG; F_UDMI(f,t,2) = QWallRG; C_UDMI(c0,t0,3) = TBulk; F_UDMI(f,t,3) = TBulk; C_UDMI(c0,t0,4) = TWadj; F_UDMI(f,t,4) = TWadj; C_UDMI(c0,t0,5) = whtcRG; F_UDMI(f,t,5) = whtcRG; } end_f_loop(f,t) } } } Cell Thread 89742640 pipe_solid-non-overlappingskipping thread Cell Thread 89581616 pipe_fluid-non-overlappingskipping thread Cell Thread 89420592 pipe_interface-wall1-1-1skipping thread Cell Thread 89903664 pipe_interface-wall1-1-1-shadowskipping thread Cell Thread 86909472 interior-fluidskipping thread Cell Thread 87070496 inletskipping thread Cell Thread 87231520 outletskipping thread Cell Thread 87392544 pipe_fluidBegin F loop Cell Thread 88369344 interior-solidskipping thread Cell Thread 88518224 wall-solidskipping thread Cell Thread 88667104 pipe_solidskipping thread Cell Thread 88828128 htfx_bcskipping thread ================================================== ============================ Node 0: Process 381551: Received signal SIGSEGV. ================================================== ============================ The fluent process could not be started. |
November 24, 2020, 13:18 |
Rep Power: 26 |
Do you get the same if you replace
kt = C_K_L(c0,t0); By kt = 0.0; ? |
November 26, 2020, 10:27 |
#3 | |
Tyler Richardson
Rep Power: 8 |
Turns out the problem was as follows: 1) I was retrieving gradient data (C_T_G) and that is only stored if you request it 2) I was storing calculations to UDMI_F() on an interface… you can only store face values to walls and boundaries…. |
htc, sigsegv, udf |
Error SIGSEGV for a simulation with UDF | francescolab | Fluent UDF and Scheme Programming | 1 | July 10, 2019 03:50 |
Problems running icoFoam: sigSegv with 4x mesh resolution | SUBHANKAR | OpenFOAM Running, Solving & CFD | 4 | December 29, 2016 22:53 |
Problem running fluent with udf on supercomputer(batch system) | Sept24 | Fluent UDF and Scheme Programming | 3 | October 15, 2015 12:50 |
UDF running three times each iteration | marauder | Fluent UDF and Scheme Programming | 1 | August 4, 2014 09:37 |
A Loop problem when running UDF in the batch mode | Jun Geng | FLUENT | 3 | July 16, 2008 08:34 |
