heat generation inside battery
1 Attachment(s)
hi
i need a fluent udf for heat generation inside a battery cell. i wrote the udf but i get c2055 error the code is based on cell temperature and time Can anyone give me a solution or correct the code? thanks |
#include "udf.h" |
hi dear AlexanderZ
i run the code and its compiled with no error but when i run the calculation its give me this error: "the f1 process could not be started" i tried parallel and serial and this error appeared i gave constant source term and its run perfectly so problem isnt the mesh and model please help to solve problem |
allocate user defined memory location in fluent GUI
user defined -> memory -> set udm locations to 1 |
