UDF problem to obtain maximum temperature
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   November 14, 2021, 10:20
Default UDF problem to obtain maximum temperature
Erfan
erfan2000 is on a distinguished road
Hello all
I use a udf to obtain the maximum temperature in each timestep and use it in another udf.to get the maximum temperature I wrote this udf:
real tmax=0.;
DEFINE_ON_DEMAND(on_demand_calc)
 Domain *d;
 real temp;
 Thread *t;
 cell_t c;
 d = Get_Domain(1); /* Get the domain using ANSYS Fluent utility */
 /* Loop over all cell threads in the domain */
 thread_loop_c(t,d)
 /* Compute max temperature */
 /* Loop over all cells */
 begin_c_loop(c,t)
 temp = C_T(c,t); /* get cell temperature */
 if (temp > tmax || tmax == 0.) tmax = temp;
 end_c_loop(c,t)
 printf("\n Tmax = %g ",tmax);
but it prints about 11 tmax in every timestep that the first ones are 0 but the last one I think are correct.I execute this udf from execute on demand and User-Defined Function Hooks>execute at end.
Can anyone Help me please or it will work properly?
P.S: My case consist of several zones.
thanks in advanced
erfan2000 is offline   Reply With Quote
Old   November 14, 2021, 23:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
parallelize your code, make it works on several nodes
more information in ansys fluent customization manual
erfan2000 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 15, 2021, 05:19
Erfan
thank you Alexander for your help but as I'm not an expert in writing a UDF I want to know if my code works properly without any changes then I just use it.
In the first timesteps, the last printed tmax for each timestep was correct.
Old   November 16, 2021, 00:03
Alexander
as you are not an expert in writing a UDF, you've asked question here, got an answer.
now you can follow recommendations or ignore
best regards
tmax, udf
temperature store and monitoring UDF indsujin Fluent UDF and Scheme Programming 1 July 9, 2021 04:08
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 21:48
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF Wall Temperature Problem - Coordinates Marc FLUENT 1 July 3, 2008 11:10
