UDF and functions both are not showing Parabolic profile |
February 26, 2021, 07:47 |
Suraj Shembekar
Rep Power: 5 |
hello all,
i am working on the the bifurcation geometry where, 1 inlet and 2 outlet. at the inlet first i have provided UDF (fully developed parabolic profile) please find the attachment for UDF code. but in the result, it shows constant profile instead of parabolic. after this i have used the ''function'' in fluent for parabolic velocity profile as follow v_mean*(1-(r/r_max)**2) where, v_mean and r_max are constant defined and r=sqrt(x**2+y**2). but no expected result. it shows constant profile instead of parabolic. please help |
February 26, 2021, 13:36 |
Rep Power: 26 |
Could you put the code here, not in an attachment? It's very hard/annoying to open attachments from a phone, and I guess that the code is not so big.
February 27, 2021, 07:21 |
MEK
Rep Power: 9 |
This is the working UDF for 2D profile
#include "C:\Program Files\ANSYS Inc\v162\fluent\fluent16.2.0\src\udf\udf.h" DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; real h=0.003; real u=0.06392694064; /* for Re = 100 based on Diameter of cylinder */ face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = u*1.5*(1-(4*(y*y/(h*h)))); } end_f_loop(f, thread) } |
February 28, 2021, 06:33 |
Rep Power: 26 |
Your function is wrong because it assumes you work in the xy-plane, but your picture shows it's yz.
Your UDF is 2D, but should still work a bit. It's your channel centered around y=0? |
March 1, 2021, 00:35 |
#5 | |
Suraj Shembekar
Rep Power: 5 |
your right sir my function was wrong, and now i got it. your comment helps me. yes, my channel centered around y=o. |
March 1, 2021, 00:37 |
#6 | |
Suraj Shembekar
Rep Power: 5 |
i will try this UDF |
Display Modes | |
UDF to disable wall functions | Abhinand | Fluent UDF and Scheme Programming | 3 | June 15, 2020 17:05 |
UDF for 3D parabolic Inlet Profile | Sicario | FLUENT | 2 | October 2, 2018 09:57 |
How to give the coordinates of the centroid of a parabolic profil in UDF | djing | Fluent UDF and Scheme Programming | 1 | December 5, 2016 04:11 |
UDF linking Adjust and Profile macro functions | Ramkumar21194 | FLUENT | 0 | April 28, 2015 08:12 |
How to specify a transient profile with spacial variant without UDF? | joy2000 | Fluent UDF and Scheme Programming | 0 | February 6, 2013 09:51 |
