Saturation temperature UDF for evaporation-condensation |
April 13, 2021, 10:42 |
Obi
Rep Power: 9 |
I want to write a UDF for calculating the saturation temperature in a multiphase domain for simulating evaporation and condensation. I'm using a mixture model of the simulation. My domain consists of 2 phases:
1) Water vapour and air (modelled as a mixture of species) 2) Water liquid. For the mass transfer, I believe the saturation temperature is the temperature of vapour condensation or liquid evaporation according to the Lee model. My thought is that to calculate the saturation temperature on a cell by cell basis, there could be 3 instances: a) A cell only contains water vapour and air: In this case, the partial pressure of water pressure is used to calculate the saturation temperature (temperature of condensation) b) A cell only contains water liquid: In this case, the pressure of the cell is used to calculate the saturation temperature (temperature of evaporation) c) A cell contains a mixture of moist air and water liquid, the fraction which can be determined by using the C_VOF() macro. Can someone tell me if my thought process is right for this problem? The last scenario is where I'm a bit confused. How can I deal with this scenario of 2 different phases occurring inside a cell? My thought is this would lead to a calculation of 2 saturation temperatures and mass transfer is likely to occur between both phases within the cell. This phenomenon is most likely to occur at the interface. If I have two saturation temperatures for both phases, which do I return to the UDF function? |
June 20, 2021, 10:08 |
Stanlee
Rep Power: 8 |
I don't understand why you will get two Tsat.
Say you have already determined which cells are at the interfere, using C_VOF, then you can use the mole fraction of water vapour to find out the saturation temperature. Isn't it? |
udf |
UDF to get the average temperature of a face and use it to define a property | gdb | Fluent UDF and Scheme Programming | 19 | November 3, 2022 03:11 |
UDF writes the outlet temperature assignment to the inlet temperature of another calc | ZengJiChuan | FLUENT | 7 | May 27, 2020 04:14 |
UDF problem- time dependent temperature at inlet | kaeran | FLUENT | 1 | June 16, 2015 21:48 |
UDF for variable temperature with time | CaglarCoskun | Fluent UDF and Scheme Programming | 8 | January 15, 2014 09:15 |
Please Help! Temperature profile UDF for 3D geometry | subhankar_bhandari | FLUENT | 0 | August 16, 2010 08:40 |
