Problem with DEFINE_UDS_FLUX
Old   April 15, 2012, 11:55
Smile Problem with DEFINE_UDS_FLUX
Ryan
cfdmatteo is on a distinguished road
hi there,
I am learning to use DEFINE_UDS_FLUX macro, and I follow the UDF Manual
example but somehow there's a problem :
Here's my code:
#include "udf.h"
DEFINE_UDS_FLUX(ws_flux,f,t,i)
cell_t cO, c1=-1;
Thread *t0, *t1 = NULL;
real NV_VEC(psi_vec), NV_VEC(A), flux = 0.0;
c0 = F_C0(f,t);
t0 = F_C0_THREAD(f,t);
F_AREA(A,f,t);
if(BOUNDARY_FACE_THREAD_P(T))
real dens;
if(NNULP(THREAD_STORAGE(t,SV_DENSITY)))
dens=F_R(f,t);
else
dens=C_R(c0,t0);
NV_DS(psi_vec,=,F_U(f,t),F_V(f,t),F_W(f,t),*,dens) ;
flux=NV_DOT(psi_vec,A);
else
c1=F_C1(f,t);
t1=F_C_THREAD(f,t);
NV_DS(psi_vec,=,C_U(c0,t0),C_V(c0,t0),C_W(c0,t0),* ,C_R(c0,t0));
NV_DS(psi_vec,+=,C_U(c1,t1),C_V(c1,t1),C_W(c1,t1), *,C_R(c1,t1));
flux=NV_DOT(psi_vec,A)/2.0;
return flux;
And after I interpreting this macro, the command shows this error:
Error: D:\ryan\source_code\ws_flux.c: line 11: THREAD_STORE: undeclared variable
Can anybody help me? Any suggestion will be appreciated!
best regard, Ryan
cfdmatteo is offline   Reply With Quote
Old   April 16, 2012, 03:41
Andreas K
MMMSim is on a distinguished road
Hi Ryan,
I think you wrote a typo in line 11:
t0 = F_C0_THEREAD(f,t);
try
instead
good luck!
MMMSim is offline   Reply With Quote
Old   April 16, 2012, 04:05
Ryan
Originally Posted by MMMSim View Post
Hi Ryan,
try
instead
good luck!
Dear Andreas K,
Thanks for your suggestion. : )
I'v fixed the code but still getting with the same problem.
It seems the DEFINE_UDS_FLUX example of the Manual is of defect.
Since I directly copy the code of example and somehow the same
error comes up.
Old   April 16, 2012, 05:09
Ryan
Originally Posted by cfdmatteo View Post
hi there,
Here's my code:
#include "udf.h"
cell_t cO, c1=-1;
c0 = F_C0(f,t);
F_AREA(A,f,t);
real dens;
dens=F_R(f,t);
else
dens=C_R(c0,t0);
else
c1=F_C1(f,t);
t1=F_C_THREAD(f,t);
return flux;
best regard, Ryan
Well, the first problem seems to be solved since I subtitute
t0 = F_C0_THREAD(f,t) with t0 = THREAD_T0(t).
But here comes other problems :
for line 14 if(BOUNDARY_FACE_THREAD_P(T)) :
Error: D:\ryan\source_code\ws_flux.c: line 14: parse error.
and for line 20 dens = F_R(f,t); :
Error: D:\ryan\source_code\ws_flux.c: line 20: dens: undeclared variable
Any suggestion?
Ryan
Old   April 22, 2012, 03:12
chenxizhong
chenxizh is on a distinguished road
Hi, you have serval mistakes in your udf, here the correct one is following, any way do you used it in multiphase?
#include "udf.h"
cell_t c0, c1=-1;
c0 = F_C0(f,t);
F_AREA(A,f,t);
if(BOUNDARY_FACE_THREAD_P(t))
real dens;
if(NNULLP(THREAD_STORAGE(t,SV_DENSITY)))
dens=F_R(f,t);
else
dens=C_R(c0,t0);
else
c1=F_C1(f,t);
t1=F_C1_THREAD(f,t);
return flux;
Any suggestion?
Ryan
chenxizh is offline   Reply With Quote
Old   April 22, 2012, 05:24
Ryan
#include "udf.h"
cell_t c0, c1=-1;
c0 = F_C0(f,t);
F_AREA(A,f,t);
real dens;
dens=F_R(f,t);
else
dens=C_R(c0,t0);
else
c1=F_C1(f,t);
return flux;
hi
Thanks a lot for your help.
I am trying to calculate a multiphase problem. And as following your fixed code, it's still get some problem. Anyway, some say that might be a "interpreted or compiled" problem. Did you read this code by "interpreted" or by "compiled" in Fluent?
I was interpreting it and always got errors as :
Error: D:\ryan\paper comfirm\cfd_help_ws_flux.c: line 11: THREAD_STORE:undeclared variable
Old   April 22, 2012, 05:27
chenxizhong
I use complie, there is no problem in my code
notice,the scalar transport in multiphase contain the volume fraction
hi
Old   April 22, 2012, 06:18
Ryan
hi,
I appreciate for your reply, it's really helpful for me.
Old   April 22, 2012, 06:21
chenxizhong
what is the problem you are studying? I aslo used uds in multiphase, and I find that the uds is unbound.
hi,
Old   April 22, 2012, 06:37
Ryan
hi,
I study on fuel cell calculating, and I use the PEMFC module of the Fluent but somehow the model is of defect.
I think the multiphase model of this module is UFT model,but the flux term is neglected, so I try to fixed the problem by UDF.
Old   April 30, 2012, 02:27
Default Udf help
  #11
juzer_700 is on a distinguished road
Is there a predefined macro under which I can write a new model (combustion model). I dont plan to use any combustion model provided in FLUENT.
Please help. I want to link the advance combustion model to fluent.
Under which DEFINE macro should I write my code???
Any help will be appreciate.
juzer_700 is offline   Reply With Quote
Old   July 29, 2014, 04:43
sunjian is on a distinguished road
#include "udf.h"
cell_t c0, c1=-1;
c0 = F_C0(f,t);
F_AREA(A,f,t);
real dens;
dens=F_R(f,t);
else
dens=C_R(c0,t0);
else
c1=F_C1(f,t);
return flux;
Hi, chenxizh. Have you tried to calculate with this code? This code could be compiled without any error. But when iteration was run, the error access_violation occured. What do you think the problem is? I am looking forward to your reply. Thank you.
sunjian is offline   Reply With Quote
Old   January 8, 2019, 08:02
Shiyao Xuan
xuansy is on a distinguished road
Hello, sunjian. I have the same problem, can you tell me how to solve this problem. Thank you.
xuansy is offline   Reply With Quote
Old   January 8, 2019, 08:03
Shiyao Xuan
Old   January 9, 2019, 02:11
toolpost is on a distinguished road
Hi xuan. I am in same situation, but the error message is different here. My case is serial run on a Linux system. It compiles fine, but crashes in first iteration itself.
  Node 0: Process 8824: Received signal SIGSEGV.
 MPI Application rank 0 exited before MPI_Finalize() with status 2
  The fluent process could not be started.
Did you able to solve it?
toolpost is offline   Reply With Quote
Old   April 25, 2021, 09:07
qin chunqiu is on a distinguished road
Dear Shi-yao,
Have you solved this problem. In my case, the iteration is OK but results in a result contradicing to physics.
qin chunqiu is offline   Reply With Quote
Old   April 25, 2021, 12:51
pakk will become famous soon enough
Can you elaborate on the results you see? In which way do they contradict physics?
This information would help on how to fix the UDF...
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
