May 9, 2021, 08:18 |
negative cell volume problem
ali
Rep Power: 5 |
Hi all
I trying to use Six DOF UDF with one DOF rotation for simulating a moving guide vine in a water pipe with a diameter of 0.1 meter and I set mass flow rate equal to 11 kg/s for inlet boundary condition. I face this error every time. Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: #f I tried different time steps, even less than 1e-6 but the problem was not solved. this is my UDF : #include "udf.h" DEFINE_SDOF_PROPERTIES(blade, sdof_prop, dt, time, dtime) { Six_DOF_Object *sdof_obj = NULL; sdof_prop[SDOF_MASS] = 0.053; sdof_prop[SDOF_IXX] =2.2e-6; sdof_prop[SDOF_IYY] = 4e-6; sdof_prop[SDOF_IZZ] =5.5e-6; sdof_prop[SDOF_LOAD_M_X] = 0.0; sdof_prop[SDOF_LOAD_M_Y] = 0.0; sdof_prop[SDOF_LOAD_M_Z] = 0.0; sdof_prop[SDOF_SYMMETRY_X] = 0; /* normal vector of symmetry plane for half model */ sdof_prop[SDOF_SYMMETRY_Y] = 1 ;/* normal vector of symmetry plane for half model */ sdof_prop[SDOF_SYMMETRY_Y] = 0 ; /* normal vector of symmetry plane for half model */ sdof_obj = Get_SDOF_Object(DT_PU_NAME(dt)); if (NULLP(sdof_obj)) { /* Allocate_SDOF_Object must be called with the same name as the udf */ sdof_obj = Allocate_SDOF_Object(DT_PU_NAME(dt)); SDOFO_1DOF_T_P(sdof_obj) = FALSE; /* one DOF translation */ SDOFO_1DOF_R_P(sdof_obj) = TRUE; /* one DOF rotation */ SDOFO_DIR(sdof_obj)[0] = 0.0; SDOFO_DIR(sdof_obj)[1] = 1.0; SDOFO_DIR(sdof_obj)[2] = 0.0; SDOFO_CENTER_ROT(sdof_obj)[0] = 0.09354; /* only needed for one DOF rotation */ SDOFO_CENTER_ROT(sdof_obj)[1] = 0.0; /* only needed for one DOF rotation */ SDOFO_CENTER_ROT(sdof_obj)[2] = -0.01; /* only needed for one DOF rotation */ SDOFO_CONS_P(sdof_obj) = TRUE; /* constrained */ if (SDOFO_CONS_P(sdof_obj)) { SDOFO_LOC(sdof_obj) = 0.0; SDOFO_MIN(sdof_obj) = -0.1745; SDOFO_MAX(sdof_obj) = 0.1745; SDOFO_F(sdof_obj) = 0.0; /* spring preload */ SDOFO_K(sdof_obj) = 2.76; /* spring constant */ SDOFO_INIT(sdof_obj) = SDOFO_LOC(sdof_obj); SDOFO_LOC_N(sdof_obj) = SDOFO_LOC(sdof_obj); } } } these are my dynamic mesh setting: remeshing.PNG s.PNG 1.PNG |
#dynamic_mesh, #negative cell volume, #udf |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Negative Volume - apprentice | madboy19 | FLUENT | 0 | November 4, 2015 21:08 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
