Infinite Loop Scheme Script Question
Old   May 15, 2021, 20:51
Default Infinite Loop Scheme Script Question
zwong8 is on a distinguished road
I recently wrote a quick script (attached below) to generate a number of lines across my domain. However, when I read this script in Fluent, the do loop is evaluated indefinitely - beyond the specified range.
I've run the code in a scheme IDE and it works as I expect it to, so I think the error is due to Fluent's implementation of the code. I was hoping someone could give me some insight into this matter and a few related questions:
1. When the loop was running, I tried to interrupt it with "ctrl+c" as suggested, but this did not work. Is there an updated way to pause a process through the Fluent terminal?
2. Does anyone have any suggestions on how to output the, say z-velocity, along each line into a single file?
Thank you very much!
File Type: txt Linesurface_Creation.txt (491 Bytes, 3 views)
zwong8 is offline   Reply With Quote
Old   May 16, 2021, 22:22
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
(do ((n 0 (+ n 1))) ((> n N))
(begin
    (define x (+ x0 (* n dx)))
    (Ti-menu-load-string (format #f "surface/line-surface l=~ah=~a ~a ~a ~a ~a ~a ~a" x z x y0 z x y1 z))
you can get velocity using TUI commands, same as you made it here:
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
do loop, scheme file
Nested loop macro question in tecplot Rannnnnnnn Tecplot 1 January 4, 2021 14:20
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
awk script question awk script question Main CFD Forum 0 March 28, 2005 02:06
question for MILES with TVD-MUSCL scheme. CFDnet Main CFD Forum 1 February 13, 2005 17:07
Question on Sediment Mass Conservation Scheme Wen Long Main CFD Forum 0 July 6, 2004 15:45
