How to calculate area of particular surface through UDF?
Like Tree2Likes
  • 1 Post By pakk
  • 1 Post By AlexanderZ
Old   May 19, 2021, 10:44
Default How to calculate area of particular surface through UDF?
Silence is on a distinguished road
Background
Hello, everyone:
I want to calculate the area of top surface(ID=10) which is shown in Figure 1, but I encountered some problem and I cannot figure it out.
For UDF code, I searched previous examples on the internet, but I cannot fully understand the meaning of some syntax.
Problem
(1) UDF problem. I know I should find the target surface and then use the macro called F_AREA and NV_MAG to obtain area, but I don’t know how to realize it?
(2) Understanding of macro problem. The loop macro in UDF code, ‘thread_loop_f’ and ‘begin_f_loop-end_f_loop’, I know the function of these two macros, for example, to my understanding, ‘thread_loop_f(thread, domain) is to loop over thread which contains faces in domain(am I right?), but I do not know why they are here?
(3) After built and loaded UDF file successfully, once I clicked the ‘execute on demand’, error pops out, which is shown in Figure 2, why this happened?
Any help will be appreciated, thank you, I need your help.
Regards,
Silence
Figure 1
Figure 2
UDF code:
#include<iostream>
#include "udf.h"
using namespace std;
DEFINE_ON_DEMAND(Face_area)
face_t face;
Thread* thread;
Domain* domain;
domain = Get_Domain(1);
int zone_id = 6;
thread = Lookup_Thread(domain, zone_id);
real NV_VEC(va); /* Array for storing area vector */
real Area = 0;
begin_f_loop(face, thread)
F_AREA(va, face, thread); /* Obtain the area vector */
Area = NV_MAG(nc); /* Obtain area magnitude */
cout << "Area of top surface is" << Area << endl;
end_f_loop(face, thread)
Silence is offline   Reply With Quote
Old   May 19, 2021, 17:57
pakk will become famous soon enough
The images don't show up for me....
I don't understand the thread_loop_f loop here.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   May 19, 2021, 20:49
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
problem comes from the fact, that you've made few typos
compile code and check log, fix problems
the logic of code is correct, from my point of view
you may use this link as a hint if needed
Obtaining fluid properties using UDF
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   May 24, 2021, 09:54
Smile
Hello, pakk, thanks for the reply:
1.Images have been re-uploaded, I hope it works;
2.For the thread_loop, I also can’t understand(actually, I think it is wrong here), but I cannot find a way to select the target wall to apply the calculation macro, can you give me a hint about that? Thx!
Figure1
Figure2
Old   May 24, 2021, 10:30
#include "udf.h"
face_t face;
Thread* thread;
Domain* domain;
int zone_id = 10;
real Area = 0;
Area = NV_MAG(va); /* Obtain area magnitude */
Message("Area of top surface is %f", Area);
I think you must have had some compilation error, because you used variable nc that was never declared.
I did not test my code, so look for warnings/errors.
Old   May 24, 2021, 11:04
UchihaMadara is on a distinguished road
isn't NV_MAG(va) would give area of just one cell, and should be
+=NV_mag(va) instead?
UchihaMadara is offline   Reply With Quote
Old   May 24, 2021, 11:24
Yes, I missed that!
Old   May 24, 2021, 23:17
Smile
Hi, UchihaMadara, you are right, '=' should be replaced by "+=", but I am confused about the UDF calculation result, shown in Figure 3, compared with report result(I think it is the right answer), for, UDF result:
1.First, I think it is wrong;
2.Second, why there exists 5 results? The ‘message’ syntax is actually out of the loop, I can’t understand this, can you give me your advice? Thanks!
Regards,
Silence
Figure 3
Old   May 24, 2021, 23:20
Smile
#include "udf.h"
face_t face;
Thread* thread;
Domain* domain;
int zone_id = 10;
real Area = 0;
Thanks for your help, pakk, now, UDF can run correctly(here, 'Area = NV_MAG(va)' becomes 'Area += NV_MAG(va)'), but I am confused about the correctness of UDF result, compared with report result(I think it is the right answer), for, UDF result:
2.second, why there exists 5 result? The ‘message’ syntax is actually out of the loop, I can’t understand this, can you give me your advice? Thanks!
Regards,
Silence
Figure 3
Old   May 25, 2021, 00:34
You are running in paralel mode. Your simulation is split over five nodes, each nodes calculate its own area. You have to let them communicate.
Check manual for the syntax, I don't remember.
Silence likes this.
Old   May 25, 2021, 03:18
Alexander
#include "udf.h"
face_t face;
Thread* thread;
Domain* domain;
int zone_id = 10;
real Area = 0;
Area += NV_MAG(va); /* Obtain area magnitude */
#IF RP_NODE
Area = PRF_GRSUM1(Area);
#ENDIF
Message0("Area of top surface is %f", Area);
Silence likes this.
best regards
loop over face, macros, udf code
how to calculate the area of a boundary in UDF? peter FLUENT 2 May 31, 2021 20:54
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[OpenFOAM] Surface field value gives incorrect area McReijen ParaView 0 July 18, 2018 05:28
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
report surface area WITHOUT solit Ralf Schmidt FLUENT 1 June 1, 2007 10:23
