August 4, 2015, 07:56 |
Pressure force UDF with Fluent
Rakesh
Rep Power: 12 |
Hi all,
I am using a UDF to calculate the pressure force on the surface of a wing which is deforming under aerodynamic forces. A part of the code is shown here: begin_f_loop(f,t) { F_AREA(A,f,t); PF_x+ = F_P(f,t)*A[0]; PF_y+ = F_P(f,t)*A[1]; PF_z+ = F_P(f,t)*A[2]; ForceP = ForceP + F_P(f,t)*NV_MAG(A); } end_f_loop(f,t) The code works fine as a whole, but when I compare the pressure force components with that reported by FLUENT GUI (going to Results --> Reports --> Force Reports, the results don't match. However if I compare the pressure surface integral (from FLUENT reports) and ForceP (shown above in the code), they match. I am not sure why this discrepancy. Please let me know if you have any idea. Best Regards, RS |
August 11, 2015, 06:00 |
Bruno Machado
Rep Power: 12 |
This macro ( F_P(c,t) ) returns the static pressure. Check if this difference is not caused because in the report GUI the pressure force is computed by the total pressure.
The total pressure can be obtained by: operating_pressure = RP_Get_Real("operating-pressure"); real total_pressure; begin_c_loop(c,t) { real velocity_mag = cellVelocityMagnitude(c,t); total_pressure = C_P(c,t) + (C_R(c,t)*SQR(velocity_mag))/2 + operating_pressure; } |
January 20, 2020, 02:19 |
Deep Morzaria
Rep Power: 6 |
even adding the operating pressure does not make a difference. The force values still dont match. Please let me know if anyone has found the solution.
May 24, 2021, 11:35 |
Rep Power: 8 |
@Bruno Machado
Also, what is this cellVelocityMagnitude(c,t)? Couldn't find it in the reference? Could you tell where is this macro available in documentation, or, perhaps how else did you manage to obtain total pressure? |
UDF for specific heat as function of pressure | ghobold | Fluent UDF and Scheme Programming | 20 | August 22, 2019 08:19 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
Setup/monitor points of pressure and force coefficients | siw | CFX | 3 | October 22, 2010 06:07 |
correct UDF code for unsteady pressure boundary | James W | FLUENT | 0 | November 2, 2005 11:38 |
UDF in Fluent to Match Mass Flow at Pressure Outlet | Jonas Larsson | Main CFD Forum | 1 | April 29, 1999 10:44 |
