Units from UDF macros
Old   May 23, 2021, 12:28
Default Units from UDF macros
UchihaMadara is on a distinguished road
I wanted to ask about the units of the UDF macros.
Lets say I am dealing with
NV_mag(area), F_P(f,t) and F_Flux(f,t)
will their units be in m2, N/m2 and kg/s or something else? respectively?
(I ask this becuase I observed that I have build my CAD in mm, that means when I switch from fluent meshing to fluent solver I do a scale 0.001 0.001 0.001 command and then change the units with
/define units length mm so that I could place surfaces and lines easily.
And this has confused my two DEFINE_PROFILE methods in giving results in order of -16 and -10 for mass flow rates and reynolds respectively.)
UchihaMadara is offline   Reply With Quote
Old   May 24, 2021, 01:56
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
by default fluent uses SI for units: meters, seconds, Kelvin, so on.
when you load mesh, you should scale it to be in meters.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
udf, units
UDF units 2D vs. 3D destroy FLUENT 0 October 23, 2018 09:29
UDF macros for surface reaction borhan_sd@yahoo.com Fluent UDF and Scheme Programming 0 June 6, 2013 08:57
how to use TUI commands inside UDF macros??? Giacomo de Renzi FLUENT 1 May 27, 2008 05:06
UDF macros and updated mesh geometry Maziar Mahzari FLUENT 1 November 1, 2005 06:29
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 09:15
