-   Fluent UDF and Scheme Programming (https://www.cfd-online.com/Forums/fluent-udf/)
-   -   ANSYS: How to read Scheme file and change the boundary conditions (https://www.cfd-online.com/Forums/fluent-udf/236429-ansys-how-read-scheme-file-change-boundary-conditions.html)
Betelhiem May 29, 2021 15:02
I am new to ANSYS and CFD. I was trying to change the boundary conditions of transient and Laminar simulation using a scheme file. The scheme file has properties such as inlet velocity and temperature. I have successfully imported the mashed geometry to the solver, and tried to read the scheme file using the step file > read > scheme, then choose my file. I can see that the scheme file goes through when the console shows me the message Done #f. But the problem is the boundary conditions are not changing even after reading the scheme file, I don’t know what its problem is. If anyone out there notices my mistake I would appreciate your help and suggestions.
Thank you very much!
Betelhiem
pakk May 30, 2021 01:37
It sounds like you did OK, and the scheme file needs to be adjusted.
But, how can we tell without seeing the scheme file???
AlexanderZ May 30, 2021 20:08
copy first line of your scheme to fluent console, press enter
check, if it was executed according to your needs.
make it for the whole your code
