-   Fluent UDF and Scheme Programming (https://www.cfd-online.com/Forums/fluent-udf/)
-   -   Applying named expressions correctly? (https://www.cfd-online.com/Forums/fluent-udf/236567-applying-named-expressions-correctly.html)
UchihaMadara June 4, 2021 15:13
Hello all,
I wanted to ask about named expressions, as I have been told in the ansys forum that using named expressions would be better if I have to use DEFINE_PROFILE and F_PROFILE macros.
My question is
Lets say I have a circular inlet patch of a tube and I want to calculate reynolds number through this section of inlet. I have the following in my named expression
Density*VelocityMagnitude*Dia/DynamicViscosity
, where Dia is constant.
And then I use this in a friction factor formula, which goes into pressure calculation formula, that gets applied to this inlet patch.
my question is, is this applied correctly?
or it should be
Average(Density,['inlet'], weight='Area') * Average(VelocityMagnitude,['inlet'], weight='Area') * Dia  / Average(DynamicViscosity,['inlet'], weight='Area')
pakk June 5, 2021 03:06
Both expressions are Reynolds numbers. There are many ways to define a Reynolds number, and only for the simplest geometries there is an "obvious" choice.
In your case, one is a local, the other one is a global. Which one do you need? The one that was used in the friction factor calculation.
Unfortunately, this is not always specified. The best thing you can do is ask the author. Second best thing: choose what is easiest, and write in your report/article/presentation which one you used.
The good thing: it should not matter that much in the results.
