July 5, 2021, 04:38 |
Interface and contact detection problem
Rep Power: 6 |
Hello everyone,
Background I am using ‘contact detection’ to set a motion limit, but I failed, details have been shown in Figure 1, whole fluid zone consists of zone1(fluid top) and zone2(fluid film), bottom face of zone1 and top face of zone 2 are set as interface, a force is exerted on the bottom face of zone2 to realize the motion along y axis, the limit distance that motion will be stopped is set as 0.9mm(the initial distance between top face of zone2 and bot face of zone2 is 1mm), details about contact detection is shown in Figure 2, however, when the distance reaches 0.9mm, the moving wall is still in active. Besides, I found that once the bot face of zone1 and top face of zone2 are set as interface, two new faces with suffix “non-overlapping” appear, and warnings will be popped out if I choose to display them, which is shown in Figure 3. UDF for dynamic mesh and contact detection are presented. Questions (1) why contact detection fails to stop the motion? (2) face with suffix “non-overlapping” is the face that original face cuts off the interface between two faces, right? (3) why the face with suffix “non-overlapping” cannot be displayed?(I saw its type is “wall”) Any advice will be highly appreciated, thx! Regards, Figure 1 Figure 2 Figure 3 UDF Code Code:
#include <iostream> #include "udf.h" using namespace std; DEFINE_SDOF_PROPERTIES(external_force, prop, dt, time, dtime) { real force; force = 0.4; /* Basic property */ prop[SDOF_MASS] = 1; prop[SDOF_LOAD_F_Y] = force; /* Translation constraint */ prop[SDOF_ZERO_TRANS_X] = TRUE; prop[SDOF_ZERO_TRANS_Z] = TRUE; /* Rotation constraint */ prop[SDOF_ZERO_ROT_X] = TRUE; prop[SDOF_ZERO_ROT_Y] = TRUE; prop[SDOF_ZERO_ROT_Z] = TRUE; #if RP_HOST cout << "Host force value: " << force << "N" << endl; #endif } DEFINE_CONTACT(contact_props, dt, contacts) { Objp* o; face_t face; Thread* thread; Domain* domain = NULL; Dynamic_Thread* ndt = NULL; int tid, nid, n_faces; real v0dotn1, v1dotn0; real nc_mag, norm0_mag, norm1_mag; real N3V_VEC(vel_rel); real N3V_VEC(nc), N3V_VEC(nctmp); real N3V_VEC(xc), N3V_VEC(xctmp); real N3V_VEC(vel0), N3V_VEC(omega0), N3V_VEC(theta0), N3V_VEC(norm0); real N3V_VEC(vel1), N3V_VEC(omega1), N3V_VEC(theta1), N3V_VEC(norm1); if (!Data_Valid_P()) { return; } /* Define a common contact point / plane */ N3V_S(nc, =, 0.0); N3V_S(xc, =, 0.0); /* Fetch current thread ID */ tid = THREAD_ID(DT_THREAD(dt)); nid = -1; n_faces = 0; loop(o, contacts) { face = O_F(o); thread = O_F_THREAD(o); /* Skip faces on current thread */ if (THREAD_ID(thread) == tid) { continue; } /* Note ID of the other thread for posterity */ if (nid == -1) { nid = THREAD_ID(thread); } N3V_S(nctmp, =, 0.0); N3V_S(xctmp, =, 0.0); F_AREA(nctmp, face, thread); F_CENTROID(xctmp, face, thread); /** * Negative sum because wall normals * point out of the fluid domain */ N3V_V(nc, -=, nctmp); N3V_V(xc, +=, xctmp); n_faces++; } # if RP_NODE { /* Reduce in parallel */ nid = PRF_GIHIGH1(nid); n_faces = PRF_GISUM1(n_faces); PRF_GRSUM3(nc[0], nc[1], nc[2]); PRF_GRSUM3(xc[0], xc[1], xc[2]); } # endif node_to_host_int_2(nid, n_faces); node_to_host_real_3(nc[0], nc[1], nc[2]); node_to_host_real_3(xc[0], xc[1], xc[2]); if (n_faces > 0) { nc_mag = N3V_MAG(nc) + REAL_MIN; N3V_S(nc, /=, nc_mag); N3V_S(xc, /=, n_faces); } else { return; } #if RP_HOST Message ( "\nContact:: tid: %d nid: %d n_faces: %d " "Point: (%f %f %f) Normal: (%f %f %f)", tid, nid, n_faces, xc[0], xc[1], xc[2], nc[0], nc[1], nc[2] ); #endif /* Fetch thread for opposite body */ domain = THREAD_DOMAIN(DT_THREAD(dt)); thread = Lookup_Thread(domain, nid); if (NULLP(thread)) { Message("\nWarning: No thread for nid: %d ", nid); return; } else { ndt = THREAD_DT(thread); } SDOF_Get_Motion(dt, vel0, omega0, theta0); N3V_VV(norm0, =, xc, -, DT_CG(dt)); norm0_mag = N3V_MAG(norm0) + REAL_MIN; N3V_S(norm0, /=, norm0_mag); if (NULLP(ndt)) { N3V_V(norm1, =, nc); N3V_S(vel1, =, 0.0); N3V_V(vel_rel, =, vel0); } else { SDOF_Get_Motion(ndt, vel1, omega1, theta1); N3V_VV(vel_rel, =, vel0, -, vel1); N3V_VV(norm1, =, xc, -, DT_CG(ndt)); norm1_mag = N3V_MAG(norm1) + REAL_MIN; N3V_S(norm1, /=, norm1_mag); if (N3V_DOT(vel_rel, nc) < 0.0) { v1dotn0 = 2 * N3V_DOT(vel1, norm0); N3V_S(norm0, *=, v1dotn0); N3V_V(vel1, -=, norm0); SDOF_Overwrite_Motion(ndt, vel1, omega1, theta1); } } if (N3V_DOT(vel_rel, nc) < 0.0) { v0dotn1 = 1 * N3V_DOT(vel0, norm1); N3V_S(norm1, *=, v0dotn1); N3V_V(vel0, -=, norm1); SDOF_Overwrite_Motion(dt, vel0, omega0, theta0); } #if RP_HOST Message ( "\ncontact_props: Updated :: vel0 = (%f %f %f) vel1 = (%f %f %f)", vel0[0], vel0[1], vel0[2], vel1[0], vel1[1], vel1[2] ); #endif } |
Pinning the interface contact line - VOF model | pat.jachimczyk | Fluent UDF and Scheme Programming | 8 | June 21, 2022 11:12 |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
Wrong interface curvature capturing and contact line calculation at low capillary nu | Mahmoud_aboukhedr | OpenFOAM Running, Solving & CFD | 0 | April 14, 2015 14:04 |
Defining contact regions in FSI problem.!!! | sreemvlk | ANSYS | 0 | June 12, 2014 00:33 |
Problem with inserting a thermal contact resistance in domain interface. | jerryx70c | CFX | 1 | March 4, 2013 14:16 |
