UDF Using New Coordinates Instead of Original
Old   October 25, 2021, 20:25
Default UDF Using New Coordinates Instead of Original
Thomas Sprengeler
sprengeler is on a distinguished road
Hi All,
Below is my UDF that I have been working on for rotating the points of an airfoil. This code works in my previous application where I calculated a new Y value based on X, but now I just want to read the x and y coordinates, rotate them, then output the rotated coordinates. This code works but it is calculated each time step based on the previously rotated points instead of the original baseline coordinates thus creating too much rotation of the coordinates. Can anyone help so that it always reads the original x and y coordinates?
Thanks,
Thomas
#include "udf.h"
#define FTT 0.4
#define chord 1.00000
/*upper surface*/
DEFINE_GRID_MOTION(Up, domain, dt, time, dtime)
Thread *tf = DT_THREAD (dt);
face_t f;
Node *node_p;
real x,y,theta,x_s,y_s,T_max,Tmorph,freq,omega,xuc,yuc, Rux,Ruy,rcux,rcuy;
int n;
freq = 0.2;
omega = 2 * M_PI * freq;
Tmorph= 0.0555555794;
T_max = FTT+Tmorph;
x_s = 0.25*chord;
y_s = 0;
SET_DEFORMING_THREAD_FLAG (THREAD_T0 (tf));
begin_f_loop (f, tf)
f_node_loop (f, tf, n)
node_p = F_NODE(f, tf, n);
x = NODE_X(node_p);
y = NODE_Y(node_p);
if (NODE_POS_NEED_UPDATE (node_p))
NODE_POS_UPDATED (node_p);
if ( x < x_s) {
if ( CURRENT_TIME >= FTT && CURRENT_TIME <= T_max) {
theta = omega * (CURRENT_TIME - FTT);
xuc = x - x_s;
yuc = y - y_s;
Rux = ((xuc * cos(-theta)) + (yuc * sin(-theta)));
Ruy = ((xuc * -sin(-theta)) + (yuc * cos(-theta)));
rcux = Rux + x_s;
rcuy = Ruy + y_s;
NODE_Y (node_p) = rcuy ;
/*morphing stops*/
if ( CURRENT_TIME > T_max) {
theta = omega * Tmorph;
xuc = x - x_s;
yuc = y - y_s;
rcux = Rux + x_s;
rcuy = Ruy + y_s;
NODE_Y (node_p) = rcuy;
end_f_loop (f, tf);
sprengeler is offline   Reply With Quote
airfoil, ansys, fluent, fluent udf, udf
How to use UDF to get a grid cell centroid coordinates? lvanlee FLUENT 4 December 20, 2021 06:55
does Hyperthreading affect the application of UDF? SJSW Fluent UDF and Scheme Programming 11 October 10, 2018 22:28
Error code: 126 when loading parallel UDF Coop Fluent UDF and Scheme Programming 0 July 13, 2018 08:33
How to give the coordinates of the centroid of a parabolic profil in UDF djing Fluent UDF and Scheme Programming 1 December 5, 2016 03:11
UDF in Cylindrical Coordinates donmezayd Fluent UDF and Scheme Programming 0 April 19, 2012 03:14
