September 10, 2021, 03:20 |
temperature initialization
feride kutbay
Hello cfd online members,
I want to give the initial temperature value on surfaces on my model. I wrote udf code. it works fine for one geometry whereas another model has never work. I tried some things. and I changed the face ID for the new model. To be clear, I will give the steps I did. 1). I wrote udf code as follow; #include "udf.h" DEFINE_INIT(my_init_funcf7,domain) { real F_T; face_t f; int ID=15; /* loop over all cell threads in the domain */ Thread *thread = Lookup_Thread(domain,ID); #if RP_NODE begin_f_loop(f,thread) { F_T(f,thread)=374; } end_f_loop_all(f,thread) #endif } //f8 DEFINE_INIT(my_init_funcf8,domain) { real F_T; face_t f; int ID=16; /* loop over all cell threads in the domain */ Thread *thread = Lookup_Thread(domain,ID); #if RP_NODE begin_f_loop(f,thread) { F_T(f,thread)=373; } end_f_loop_all(f,thread) #endif } 2) interpreted to udf and the hooking is done 3). the standard initialization is achieved. These steps worked fine with one model but for another model doesn't work. I tried another type udf as follows. but it doesn't work still. #include "udf.h" DEFINE_INIT(my_init_funcb5,domain) { int F_T; face_t f; int ID=70; Thread *t1 = Lookup_Thread(domain,9); Thread *t2 = Lookup_Thread(domain,10); thread_loop_f(t1, domain)/* loops over all face threads in a domain*/ { begin_f_loop(f,t1) { F_T(f,t1)=436; } end_f_loop_all(f,t) } thread_loop_f(t2, domain)/* loops over all face threads in a domain*/ { begin_f_loop(f,t2) { F_T(f,t1)=436; } end_f_loop_all(f,t) } } thank you |
September 10, 2021, 06:19 |
Rep Power: 26 |
When you say that the code does not work for a geometry, what does that mean? It crashes, it gives wrong results, it gives no results, the simulation diverges... Which one is it?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
September 10, 2021, 06:33 |
#3 | |
feride kutbay
Hello pakk, it doesn't assign specfied temperatures to faces. it initializes with operating temperature. |
September 10, 2021, 14:27 |
Rep Power: 26 |
Then I can only guess that the thread id is different in the other geometry.
September 13, 2021, 01:55 |
Alexander
Rep Power: 34 |
as you've defined threads explicitly in your code
you don't need to loop over thread anymore for thread with ID 9 and 10 your code looks like this: (values 9 and 10 are ddifferent for each case, check in fluent graphical interface) Code:
#include "udf.h" DEFINE_INIT(my_init_funcb5,domain) { face_t f; Thread *t1 = Lookup_Thread(domain,9); Thread *t2 = Lookup_Thread(domain,10); begin_f_loop(f,t1) { F_T(f,t1)=436; } end_f_loop_all(f,t1) begin_f_loop(f,t2) { F_T(f,t2)=436; } end_f_loop_all(f,t2) }
best regards ****************************** press LIKE if this message was helpful |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
Static temperature and Total temperature | Jong-Yoon | FLUENT | 0 | September 25, 2016 01:42 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
