UDF operates as a function of liquid fraction |
October 22, 2021, 15:38 |
Erfan
Rep Power: 4 |
Hello dear all
I am new to Fluent and I have a problem with writing a UDF. I have a case consisting of phase change material(PCM) that is fully solid at first and a mini-channel with the water inlet on top of that. want to write a UDF to change water inlet velocity as PCM liquid fraction reaches 0.2. the liquid fraction is defined in the report definition. Thanks in advance |
October 25, 2021, 00:15 |
Alexander
Rep Power: 34 |
to control boundary condition one may use DEFINE_PROFILE macro
best regards ****************************** press LIKE if this message was helpful |
pcm, udf, velocity |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Can I define density in terms of liquid fraction in UDF? | mariam.sara | Fluent UDF and Scheme Programming | 21 | August 25, 2019 23:56 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
