Adding Source Terms in Specific Cells
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   October 24, 2021, 09:26
Post Adding Source Terms in Specific Cells
Cooper24 is on a distinguished road
I am modelling a 2 phase flow using VOF in FLUENT. I want to add some source terms in the N-S equations and energy equations. I need to add this source terms in the cells at the interface of 2 phases. I have written a UDF to identify these cells at every iteration.
I am using F_C0 and F_C1 to get the index of cells at the interface. For example, real cell_t c1 = F_C0(c,t). Then I storing this c1 in a user define memory location(C_UDMI).
Now, I want to apply source in these cells with the index c1. So my question is can I use a if condition in DEFINE_SOURCE like:
if(c == C_UDMI(c,t,i))
source = .................
else
source = 0;
Is it the correct way or am I doing it wrong? Any help is much appreciated.
Thanks in advance.
Cooper24 is offline   Reply With Quote
Old   October 25, 2021, 00:33
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I suggest you to use other approach
once you've found c0,t0,c1,t1
use
 C_UDMI(c0,t0,0)= 1, C_UDMI(c1,t1,0)= 1
so you will get a flag to check if cell is adjusted to interface
in define_source you'll need to check that flag
if(C_UDMI(c,t,i) == 1)
Cooper24 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 25, 2021, 03:06
Thanks a lot for your suggestion. I will try that. Till now I was going with
Also can you suggest if I am doing it right by using F_C0 and F_C1 to get the interfacial cells? I have been stuck with this for a long time now without any help. I am new to UDF writing and have written a UDF to track the interfacial cells but it is not working. I had posted this earlier in the forum also.
Thanks.
Old   October 25, 2021, 04:13
Alexander
from my point of view, if you need boundary between two phases while you are using VOF, then you don't need c0,c1
thre is a macro to check phase vof concentration C_VOF which will return you [0..1] depends on the phase inside the cell
so your you may check C_VOF in cell and consider it's boundary (which you called interface) in case C_VOF >0.5 and C_VOF <= 1
value 0.5 could be different
hope you get the idea
best regards
Old   October 25, 2021, 09:22
Actually earlier I was using this criteria only(0.01<C_VOF<1). Then I read a few papers and in those, authors had continuously tracked the interface using UDF. This is because, I am melting solid so when solid melts, iso surface for volume frction will change and I need to track the interface. So, I started writing a UDF for this taking help from the forum.
Thanks
interface capture, two phase flow, udmi, vof multiphase
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
